push lock fittings #2816949
09/04/20 10:41 AM
09/04/20 10:41 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Can any hose be used with the push lock fittings or does that take a special hose? I would like to use black braided hose on these push locks.
Re: push lock fittings [Re: mopar dave] #2816952
09/04/20 10:44 AM
09/04/20 10:44 AM
AndyF Offline
AndyF  Offline
Follow the instructions. The mfg tells you which fittings go with which hose.
Re: push lock fittings [Re: AndyF] #2816954
09/04/20 10:48 AM
09/04/20 10:48 AM
Mt Morris Michigan
Mt Morris Michigan
I bought them off Ebay last year and can't remember the brand. I do know the hose i have would be a super tight fit on the fittings, not sure i could even get these to slide on. ok, Thanks Andy
Re: push lock fittings [Re: mopar dave] #2817019
09/04/20 01:20 PM
09/04/20 01:20 PM
AndyF Offline
AndyF  Offline
Mixing and matching random parts is not a good idea. Different vendors will sell different styles of push lock type hose. I wouldn't mix and match random parts on a race car, especially on fuel or oil lines. If one blows off you'll have a big problem. When I use push lock stuff I only buy from one vendor so I know everything I have will work.
Re: push lock fittings [Re: mopar dave] #2817082
09/04/20 04:36 PM
09/04/20 04:36 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I echo Andy's sediments here. Fuel and fluid lines are no place to gamble, especially with sub par chinese fittings. I watched a buddy almost drive his car through the starting line booth last year when a box store brand oil fitting broke and sent oil under the car. You get what you pay for.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: push lock fittings [Re: A39Coronet] #2817131
09/04/20 09:13 PM
09/04/20 09:13 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, i bought a non push lock fitting. Really didn't feel like having a fire. Thanks for the help guys
Re: push lock fittings [Re: mopar dave] #2817157
09/04/20 10:04 PM
09/04/20 10:04 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Re: push lock fittings [Re: mopar dave] #2817179
09/04/20 10:52 PM
09/04/20 10:52 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
You can use just about any socketless/push lock fittings with a hose designed for such hose end fittings. The basic SAE code for such hose is 100R6. You can mix and match these style of hoses and fittings without too much worry. Not so much with fittings that are reusable or crimped. They need to match like Garanimals clothing.
The application and pressures will also come into play with hose end selection.
