E-Body 727 column shift linkage #2816764
09/03/20 05:56 PM
09/03/20 05:56 PM
Alabama
David1971 Offline OP
Alabama
Is the torque shaft support bracket that mounts on the side of the transmission the same for both a 904 and 727? Or is one longer than the other? Also, is it different from the bracket used with console shift linkage? This bracket is missing on my column shift 70 Cuda 440.
Thanks,
David
Re: E-Body 727 column shift linkage [Re: David1971] #2816773
09/03/20 06:30 PM
09/03/20 06:30 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I don't know on an e-body, but on the a-body cars several of those shift mechanism parts are different lengths between the 904 and 727 cars. If nobody else can confirm I would seek out the 727 part so you know it works.
Re: E-Body 727 column shift linkage [Re: David1971] #2817057
09/04/20 03:24 PM
09/04/20 03:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The E-body torque shaft is the same for 727 and 904, bracket is different; the 904 bracket is longer because of the narrower case.
Re: E-Body 727 column shift linkage [Re: John_Kunkel] #2817074
09/04/20 04:21 PM
09/04/20 04:21 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
different brackets for the 904 and 727 and yes the bracket is the same for console shifted or column shifted cars
Re: E-Body 727 column shift linkage [Re: David1971] #2817525
09/05/20 05:13 PM
09/05/20 05:13 PM
Alabama
Alabama
I have looked at a number of images of these side-mounted brackets...all on the web. I have also looked at Dave Wise's documentation. Based on the replies here and what I have viewed, I think that this bracket, found on Ebay, is the correct one. Went ahead and bought it. I will replace the bushing.
Thanks to everyone here for their help,
David
