E-Body 727 column shift linkage
#2816764
09/03/20 05:56 PM
09/03/20 05:56 PM
Posts: 203 Alabama
David1971
Alabama
Is the torque shaft support bracket that mounts on the side of the transmission the same for both a 904 and 727? Or is one longer than the other? Also, is it different from the bracket used with console shift linkage? This bracket is missing on my column shift 70 Cuda 440.
Thanks, David
Re: E-Body 727 column shift linkage
[Re: David1971]
#2817057
09/04/20 03:24 PM
09/04/20 03:24 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The E-body torque shaft is the same for 727 and 904, bracket is different; the 904 bracket is longer because of the narrower case.
