Re: Fluidampr (viscous damper)
[Re: Moe]
#2815685
08/31/20 09:31 PM
08/31/20 09:31 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
BS I ran 2 for years with zero issues - one at 800 hp. Bearings were always fine.
[Re: Moe]
#2815771
09/01/20 08:56 AM
09/01/20 08:56 AM
Posts: 22,696 Bitopia
jcc
Bitopia
On another message board a member writes"A lot of engine builders will not run the fluidampr, they say they can crack a crank"
Is this true......or BS?? True, as in every dampner can break a crank under the right conditions. So the real question should be, is the fluidampner you have chosen the right/best solution for your application. It is a "BS" statement you have shared from the other board in that it omits a lot of important details.
