65 Coronet - Fiberglass fenders vs. Steel #2814284
08/28/20 11:29 AM
08/28/20 11:29 AM
COLUMBUS, OH
W
Whompin_Wedge Offline OP
W
COLUMBUS, OH
I am sure this topic has been beat to death...
But does anyone know the approximate weight difference between fiberglass and steel fenders? It's for a 65 coronet, but really just looking for a ballpark figure.
Thank you,
Casey FJ
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: Whompin_Wedge] #2814316
08/28/20 12:00 PM
08/28/20 12:00 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
On my 68 Road Runner, it was a 30lb difference, for the pair.
69 GTX 68 Road Runner
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: Whompin_Wedge] #2814355
08/28/20 01:05 PM
08/28/20 01:05 PM
There is not a lot of weight savings on the fenders only, especially with fibreglass. Carbon fiber and Kevelar is a lot lighter per fender than fibreglass but way more expensive.
I would look at a one piece frontend with a lift off hood so you get the weight savings on the bumper and brackets, grill, headlights, hood and as well as the fender weight savings scope
The fibreglass doors are the best weight savings on most early Mopars scope
My 1970 Cuda fibreglass doors with the small diameter steel tube frames for the lexan windows with the stock OEM Mopar steel hinges don't weigh 15.0 bs each boogie
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: Cab_Burge] #2814369
08/28/20 01:40 PM
08/28/20 01:40 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Casey runs NSS. One piece front end are not allowed.
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: Whompin_Wedge] #2814374
08/28/20 01:46 PM
08/28/20 01:46 PM
AndyF Offline
AndyF  Offline
Thank you,
Casey FJ
Depends on the parts. The Coronet fenders are not super heavy by themselves and some glass parts are pretty heavy depending on who laid them up. You might be able to save 5 to 10 lbs per fender depending on which parts you use. Most fiberglass fenders fit like crap so if you want the car to look nice you'll spend a lot of time and money at the body shop.
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: AndyF] #2814398
08/28/20 02:17 PM
08/28/20 02:17 PM
COLUMBUS, OH
W
W
COLUMBUS, OH
Correct no 1 piece allowed for me.
That’s exactly what I needed to know guys. Thank you. I am getting aluminum brackets for the fiberglass bumpers and will look at other options for weight savings.
Casey FJ
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: Whompin_Wedge] #2814438
08/28/20 04:04 PM
08/28/20 04:04 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Trunk lid is super heavy.
I'd swap that out first with a fiberglass piece.
Best money sent. Fenders are worth the cost vs. Weight.
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: Whompin_Wedge] #2814442
08/28/20 04:06 PM
08/28/20 04:06 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
AAR Fiberglass makes front fenders for a 65 Dodge. $450 each plus shipping. Like I said, I saved 30lbs on the front fenders for my Road Runner.
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: JERICOGTX] #2814443
08/28/20 04:09 PM
08/28/20 04:09 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Front fenders from AAR, as are the bumpers. Aluminum brackets are from Lingenfelter Brackets.
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: JERICOGTX] #2814654
08/29/20 10:23 AM
08/29/20 10:23 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
the deck lid is where you can get some real savings - doors are another - Jeff's bumper brackets are real good for a few pounds - you can always let Russ show you what you can do with a hole saw and a cut-off wheel
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: DoubleD] #2814662
08/29/20 11:05 AM
08/29/20 11:05 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
450 beans EACH ... where were you apimp Back a while ago ?
WHAT do those fenders weigh each ?
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: DoubleD] #2814965
08/29/20 11:26 PM
08/29/20 11:26 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Have hole saw will travel ======= sawzall
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: JERICOGTX] #2814972
08/29/20 11:56 PM
08/29/20 11:56 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
FWIW, I spoke with AAR on Fri regarding Dart fenders, they will not do CF, and they don't stock fenders, they don't know or are not willing to share the weight of their FG fenders, and they do not make a race weight FG fender. bawling
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: jcc] #2815091
08/30/20 12:45 PM
08/30/20 12:45 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Oh my gooooness .... for a liberal arts major to comment LIKE THIS .... eek
AAR is a little bizarreO !
I’ll HOLD MY TONGUE unless invited to comment further ... smoke
REimagine THAT ... from the ole Doc ! penguin
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: max_maniac] #2815719
08/31/20 11:56 PM
08/31/20 11:56 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
I don’t want you to put an eye out!
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: poppaj] #2815798
09/01/20 09:43 AM
09/01/20 09:43 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Lexan and no regulators. Side windows, a little door trimming and back window saved 88lbs. Still have the glass windshield. Aluminum drive shaft helps. Stock rear trunk lid is close to 55lbs.
Doug
Re: 65 Coronet - Fiberglass fenders vs. Steel [Re: Whompin_Wedge] #2815815
09/01/20 10:28 AM
09/01/20 10:28 AM
New York
polyspheric Offline
polyspheric  Offline
New York
W/r/t weight saving per dollar spent:
Remember to add in the extra 3 days of prep your body guy needs to make the fenders fit, some I've seen look like they were wrung out like a washcloth.
I spoke to a body guy about how to make them straight permanently. I said if you can clamp them into good position, you can glass a strut inside from wood or conduit. He said ".......... what?".
Remember the shipping/insurance rule:
If the box is good and the contents are bad: it's the shipper's fault.
If the box is bad: it's the carrier's fault.
Boffin Emeritus
