Page 1 of 3 1 2 3
De-stroked Hemi possibilities? #2812519
08/24/20 11:46 AM
08/24/20 11:46 AM
Minnesota
Hemi_Joel Offline OP
Minnesota
For a racing class that requires pre 74 American production iron block and heads, with a 370 cubic inch limit, naturally aspirated, where maximum power is everything, how do you think a 4.25 x 3.25, high rpm Hemi would work out? I already have a set of iron heads that will flow 420i 315e. The Wallace calculator says these heads at this cid will make 900+ horse at 10,000 - 11,000 rpm. How high can this size hemi reliably rev, assuming all the best stuff?
What has been done like this already?
How would you build it?
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812522
08/24/20 11:51 AM
08/24/20 11:51 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
You would have to talk with either Ray Barton, or Charlie Wescott about this type of stuff, as SS/AH engines are turning those kind of RPM's.
69 GTX 68 Road Runner
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812524
08/24/20 11:56 AM
08/24/20 11:56 AM
Locomotion Offline
Locomotion  Offline
John Hagen / Charlie Malyuke B-Block Pro Stock baby Hemi
There are a couple of engines still floating around. But I don't know if they are for sale or how much. It would be expensive to fix or duplicate.
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812526
08/24/20 11:57 AM
08/24/20 11:57 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Sounds like one of those classes where the deepest pockets win.
Re: De-stroked Hemi possibilities? [Re: Locomotion] #2812527
08/24/20 11:58 AM
08/24/20 11:58 AM
Minnesota
Minnesota
Also, no welding is allowed other than repairs. So I couldn't convert a low deck block. It would have to be a Hemi block.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812531
08/24/20 12:05 PM
08/24/20 12:05 PM
Minnesota
Minnesota
Maybe a guy could convert a low deck without welding? I'd have to take a closer look
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: fast68plymouth] #2812532
08/24/20 12:06 PM
08/24/20 12:06 PM
Minnesota
Minnesota
You're a smart man. You know darn well it takes more than money to win. The whole purpose for this class is to keep costs down by eliminating aftermarket blocks and heads, NASCAR motors, blowers, nitrous, turbos, and all that expensive stuff. But any real racing cost money.
Here's a topic that you will appreciate more:. bucks down racing
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812550
08/24/20 12:20 PM
08/24/20 12:20 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I’m pretty sure I know what your thinking is on this Joel.... you need to focus on one thing at a time.
Re: De-stroked Hemi possibilities? [Re: JERICOGTX] #2812551
08/24/20 12:22 PM
08/24/20 12:22 PM
Minnesota
Minnesota
One thing at a time? That train left about 40 years ago
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812552
08/24/20 12:24 PM
08/24/20 12:24 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Originally Posted by Hemi_Joel
[quote=fast68plymouth] The whole purpose for this class is to keep costs down by eliminating aftermarket blocks and heads
Does that work though? Not sure if you are allowed the same mods but thought I read SS/AH hemi heads were something like 30k.
Those have a lot of welding/epoxy I believe however.
Are you allowed to do anything similar or need to keep original port locations?
Re: De-stroked Hemi possibilities? [Re: JERICOGTX] #2812558
08/24/20 12:40 PM
08/24/20 12:40 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The other possibility is the G1 354/392 Hemis....We have a couple of them around here in the gasser AA class running in the 4's in the 1/8th mile....Blown of course, but they rev them up there real good. They were supposed to come out with a new 392 G1 Hemi block last year, but it seems that's not happening. That would have been the direction I would have tried. You would need to call Oddy on his setup, its a wicked 4.8 car....
So if I were to attempt it with a G2, I would say a low deck Hemi block would be where I want to start if that's even possible. Wasn't one of the new block manufacturers making a block that could be machined as a Hemi or a Wedge? If he has a Low deck, that would be awesome. Use a billet center weighted crank, and go from there....Its the block that will be the issue I think...Barton already has the high rpm rocker train figured out, so its a great place to start with a SS/AH that's de-stroked...
One other thing....Lets just say you built it, and it worked, and you won a race....They would ban you as fast as they could.
Re: De-stroked Hemi possibilities? [Re: Dragula] #2812580
08/24/20 01:34 PM
08/24/20 01:34 PM
Minnesota
Minnesota
I think the only thing that works to really hold costs down is a claiming rule like they have in circle track.
I've seen bracket racing cars that I'm sure are a strong six-figure operation.
from my efforts in my drag week hot rod coupe, I've learned a lot about the drawbacks of the first gen Hemi in naturally aspirated, mainly a small bore that hinders breathing. I know in naturally aspirated, it's a lot easier and cheaper per horsepower to build a Gen 2 Hemi.
It needs to be a production block, no aftermarket blocks. One thing I'm getting clarification on is if the Mopar performance iron replacement Hemi block is allowed.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812582
08/24/20 01:40 PM
08/24/20 01:40 PM
What bore and stroke are you looking at?
I remember the destroke 366 C.I. Pro Stock gen 2 Hemi not running that good compared to the other longer stroke 426 hemi motors being used back then shruggy
I'm thinking a 4.310 bore with a short enough stroke to make your goal with ultra light good pistons may fit your needs luck
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812585
08/24/20 01:47 PM
08/24/20 01:47 PM
A727Tflite Offline
A727Tflite  Offline
Thanks, Joel
Late 70’s technology :
.030” over standard Hemi block, 6.96” NASCAR rod (can you say heavy?), standard 3.48” Direct Connection crank, DC race piston @ 12.5 to 1 (can you say heavy?) with Dykes rings, stock street Hemi heads port matched and bowls cleaned up, .750 roller, Rat Roaster manifold, auto trans, 10.5 x 30 tire. A/SM. Ran 10.30’s at 133+. Never could hook it up, but it ran out the back door like a freight train turning it 8500. Never broke anything and it was raced a lot.
This same package we went to a tunnel ram with 2 dominators, ported the heads - I think they flowed 350-370 back then, at 3400 #’s in B/MP went 9.70’s.
Current technology, light Diamond pistons, light rods, better valve gear, better intake, scrapper, who knows what that is worth.
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812602
08/24/20 02:18 PM
08/24/20 02:18 PM
New York
polyspheric Offline
polyspheric  Offline
New York
You're at the bottom of the learning curve. Very little tune-up data crosses over.
Boffin Emeritus
Re: De-stroked Hemi possibilities? [Re: polyspheric] #2812608
08/24/20 02:31 PM
08/24/20 02:31 PM
Minnesota
Minnesota
That's why I'm asking. up
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: A727Tflite] #2812610
08/24/20 02:32 PM
08/24/20 02:32 PM
Minnesota
Minnesota
Good info, thanks
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812615
08/24/20 02:42 PM
08/24/20 02:42 PM
Minnesota
Minnesota
Porting and milling of heads OK, epoxy OK, no brazing or welding on heads or block. Block can be decked up to .125.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812634
08/24/20 03:17 PM
08/24/20 03:17 PM
A727Tflite Offline
A727Tflite  Offline
What induction system is allowed, sheet metal ? Carb rules ?
Vacuum pump allowed?
That A/SM motor used a single 850 with choke tower in place.
Re: De-stroked Hemi possibilities? [Re: A727Tflite] #2812635
08/24/20 03:20 PM
08/24/20 03:20 PM
A727Tflite Offline
A727Tflite  Offline
By the way, I have one set of new .030” pistons and rods from the backup motor we never built. I also have good used 3.48” crank, full radius fillet if you want to try and build one on the cheap (cheaper).
Page 1 of 3 1 2 3
