De-stroked Hemi possibilities?
#2812519
08/24/20 11:46 AM
08/24/20 11:46 AM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
For a racing class that requires pre 74 American production iron block and heads, with a 370 cubic inch limit, naturally aspirated, where maximum power is everything, how do you think a 4.25 x 3.25, high rpm Hemi would work out? I already have a set of iron heads that will flow 420i 315e. The Wallace calculator says these heads at this cid will make 900+ horse at 10,000 - 11,000 rpm. How high can this size hemi reliably rev, assuming all the best stuff?
What has been done like this already?
How would you build it?
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: De-stroked Hemi possibilities?
[Re: Hemi_Joel]
#2812522
08/24/20 11:51 AM
08/24/20 11:51 AM
Posts: 10,021 MN
JERICOGTX
MN
You would have to talk with either Ray Barton, or Charlie Wescott about this type of stuff, as SS/AH engines are turning those kind of RPM's.
69 GTX
68 Road Runner
[Re: Hemi_Joel]
#2812526
08/24/20 11:57 AM
08/24/20 11:57 AM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Sounds like one of those classes where the deepest pockets win.
[Re: Locomotion]
#2812527
08/24/20 11:58 AM
08/24/20 11:58 AM
Hemi_Joel
Minnesota
Also, no welding is allowed other than repairs. So I couldn't convert a low deck block. It would have to be a Hemi block.
[Re: Hemi_Joel]
#2812531
08/24/20 12:05 PM
08/24/20 12:05 PM
Hemi_Joel
Minnesota
Maybe a guy could convert a low deck without welding? I'd have to take a closer look
[Re: fast68plymouth]
#2812532
08/24/20 12:06 PM
08/24/20 12:06 PM
Hemi_Joel
Minnesota
Sounds like one of those classes where the deepest pockets win. You're a smart man. You know darn well it takes more than money to win. The whole purpose for this class is to keep costs down by eliminating aftermarket blocks and heads, NASCAR motors, blowers, nitrous, turbos, and all that expensive stuff. But any real racing cost money. Here's a topic that you will appreciate more:. bucks down racing
[Re: Hemi_Joel]
#2812550
08/24/20 12:20 PM
08/24/20 12:20 PM
Posts: 10,021 MN
JERICOGTX
MN
I’m pretty sure I know what your thinking is on this Joel.... you need to focus on one thing at a time.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2812551
08/24/20 12:22 PM
08/24/20 12:22 PM
Hemi_Joel
Minnesota
I’m pretty sure I know what your thinking is on this Joel.... you need to focus on one thing at a time. One thing at a time? That train left about 40 years ago
[Re: Hemi_Joel]
#2812552
08/24/20 12:24 PM
08/24/20 12:24 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
[quote=fast68plymouth] The whole purpose for this class is to keep costs down by eliminating aftermarket blocks and heads Does that work though? Not sure if you are allowed the same mods but thought I read SS/AH hemi heads were something like 30k. Those have a lot of welding/epoxy I believe however. Are you allowed to do anything similar or need to keep original port locations?
[Re: JERICOGTX]
#2812558
08/24/20 12:40 PM
08/24/20 12:40 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
The other possibility is the G1 354/392 Hemis....We have a couple of them around here in the gasser AA class running in the 4's in the 1/8th mile....Blown of course, but they rev them up there real good. They were supposed to come out with a new 392 G1 Hemi block last year, but it seems that's not happening. That would have been the direction I would have tried. You would need to call Oddy on his setup, its a wicked 4.8 car....
So if I were to attempt it with a G2, I would say a low deck Hemi block would be where I want to start if that's even possible. Wasn't one of the new block manufacturers making a block that could be machined as a Hemi or a Wedge? If he has a Low deck, that would be awesome. Use a billet center weighted crank, and go from there....Its the block that will be the issue I think...Barton already has the high rpm rocker train figured out, so its a great place to start with a SS/AH that's de-stroked...
One other thing....Lets just say you built it, and it worked, and you won a race....They would ban you as fast as they could.
[Re: Dragula]
#2812580
08/24/20 01:34 PM
08/24/20 01:34 PM
Hemi_Joel
Minnesota
I think the only thing that works to really hold costs down is a claiming rule like they have in circle track. I've seen bracket racing cars that I'm sure are a strong six-figure operation.
from my efforts in my drag week hot rod coupe, I've learned a lot about the drawbacks of the first gen Hemi in naturally aspirated, mainly a small bore that hinders breathing. I know in naturally aspirated, it's a lot easier and cheaper per horsepower to build a Gen 2 Hemi.
It needs to be a production block, no aftermarket blocks. One thing I'm getting clarification on is if the Mopar performance iron replacement Hemi block is allowed.
[Re: Hemi_Joel]
#2812582
08/24/20 01:40 PM
08/24/20 01:40 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
What bore and stroke are you looking at? I remember the destroke 366 C.I. Pro Stock gen 2 Hemi not running that good compared to the other longer stroke 426 hemi motors being used back then I'm thinking a 4.310 bore with a short enough stroke to make your goal with ultra light good pistons may fit your needs
[Re: Hemi_Joel]
#2812585
08/24/20 01:47 PM
08/24/20 01:47 PM
Posts: 3,069 Michigan
A727Tflite
Thanks, Joel Late 70’s technology : .030” over standard Hemi block, 6.96” NASCAR rod (can you say heavy?), standard 3.48” Direct Connection crank, DC race piston @ 12.5 to 1 (can you say heavy?) with Dykes rings, stock street Hemi heads port matched and bowls cleaned up, .750 roller, Rat Roaster manifold, auto trans, 10.5 x 30 tire. A/SM. Ran 10.30’s at 133+. Never could hook it up, but it ran out the back door like a freight train turning it 8500. Never broke anything and it was raced a lot. This same package we went to a tunnel ram with 2 dominators, ported the heads - I think they flowed 350-370 back then, at 3400 #’s in B/MP went 9.70’s. Current technology, light Diamond pistons, light rods, better valve gear, better intake, scrapper, who knows what that is worth.
[Re: Hemi_Joel]
#2812602
08/24/20 02:18 PM
08/24/20 02:18 PM
Posts: 4,206 New York
polyspheric
New York
You're at the bottom of the learning curve. Very little tune-up data crosses over.
Boffin Emeritus
[Re: polyspheric]
#2812608
08/24/20 02:31 PM
08/24/20 02:31 PM
Hemi_Joel
Minnesota
You're at the bottom of the learning curve. Very little tune-up data crosses over. That's why I'm asking.
[Re: A727Tflite]
#2812610
08/24/20 02:32 PM
08/24/20 02:32 PM
Hemi_Joel
Minnesota
Good info, thanks
[Re: Hemi_Joel]
#2812615
08/24/20 02:42 PM
08/24/20 02:42 PM
Hemi_Joel
Minnesota
Porting and milling of heads OK, epoxy OK, no brazing or welding on heads or block. Block can be decked up to .125.
[Re: Hemi_Joel]
#2812634
08/24/20 03:17 PM
08/24/20 03:17 PM
A727Tflite
Porting and milling of heads OK, epoxy OK, no brazing or welding on heads or block. Block can be decked up to .125. What induction system is allowed, sheet metal ? Carb rules ? Vacuum pump allowed? That A/SM motor used a single 850 with choke tower in place.
