Re: where to get the small gaskets in a edelbrock carb
[Re: Mopar Ron]
#281098
04/07/09 11:23 PM
04/07/09 11:23 PM
RapidRobert
if you have some extra gasket material from any kit just use a razor blade/exacto knife & cut your own. Havent done it but I dont see why it couldn't work expecially since alot of tailor made gaskets need a bit of trimming anyhow.
[Re: RapidRobert]
#281100
04/08/09 12:07 AM
04/08/09 12:07 AM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
they are pretty small and many holes, I think they could be made with some skill and patients but I would like to just find some someplace Ron....
[Re: Mopar Ron]
#281101
04/08/09 01:46 AM
04/08/09 01:46 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
Ron they might sell that in a seperate kit , which ones do you need ?
[Re: JohnRR]
#281102
04/08/09 08:07 AM
04/08/09 08:07 AM
Posts: 15,487 Florida
scratchnfotraction
yea they sell just a gasket kit..was about 12-13$ last time I got one its in the eddy catalog I would not try to cut my own, they are a little complex on the lay,IMO most time I have to order it...most places wont have it on the shelf my speed shop keeps one around now that I bug them all the time about it...mostly chivy/ferd crap in there any ways but...he is starting to stock some stuff for us mopar guys
[Re: JohnRR]
#281103
04/08/09 10:34 AM
04/08/09 10:34 AM
Mopar Ron
I could use all 5 that I have pictured, Ill look and see if I can find JUST a gasket set, but the rebuild kit is like $50.00 I dont need the other stuff..
the carb is new and it got some stuff past the bad filter and the car started running bad so I had to take it all apart to clean out the carb and those little gaskets pulled apart a little, everything else is fine.
what happened to the $10-$15 rebuild kits I use to sell at the auto parts store Ron...
[Re: ZIPPY]
#281110
04/08/09 02:40 PM
04/08/09 02:40 PM
scratchnfotraction
I have soaked them in WD-40 for a while and they wont stick when R&R them I also do this to the 8 3/4 chunk gasket,and 9 1/4 cover gasket done this on a bunch of chivy Q-jets and other carbs that need to be opend often
