where to get the small gaskets in a edelbrock carb #281097
04/07/09 11:17 PM
04/07/09 11:17 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline OP
I cant see paying $50.00 for a whole rebuild Kit for a 600 cfm edelbrock carb.
I only need the small gaskets under the venturies and squirters. Is there any place to get just those gaskets??? Ron...
Re: where to get the small gaskets in a edelbrock carb [Re: Mopar Ron] #281098
04/07/09 11:23 PM
04/07/09 11:23 PM
if you have some extra gasket material from any kit just use a razor blade/exacto knife & cut your own. Havent done it but I dont see why it couldn't work expecially since alot of tailor made gaskets need a bit of trimming anyhow.
Re: where to get the small gaskets in a edelbrock carb [Re: Mopar Ron] #281099
04/07/09 11:30 PM
04/07/09 11:30 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Ditto, use same thickness gasket material, get a cheap punch set and make your own. Im looking for the screw-in captive check ball that goes in the accelerator pump well of an older carter AVS. Anyone got one? pishta68 at hotmail dot com
Re: where to get the small gaskets in a edelbrock carb [Re: RapidRobert] #281100
04/08/09 12:07 AM
04/08/09 12:07 AM
they are pretty small and many holes, I think they could be made with some skill and patients but I would like to just find some someplace Ron....
Re: where to get the small gaskets in a edelbrock carb [Re: Mopar Ron] #281101
04/08/09 01:46 AM
04/08/09 01:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ron they might sell that in a seperate kit , which ones do you need ?
Re: where to get the small gaskets in a edelbrock carb [Re: JohnRR] #281102
04/08/09 08:07 AM
04/08/09 08:07 AM
scratchnfotraction Offline
yea they sell just a gasket kit..was about 12-13$ last time I got one
its in the eddy catalog
I would not try to cut my own, they are a little complex on the lay,IMO
most time I have to order it...most places wont have it on the shelf
my speed shop keeps one around now that I bug them all the time about it...mostly chivy/ferd crap in there any ways
but...he is starting to stock some stuff for us mopar guys
Re: where to get the small gaskets in a edelbrock carb [Re: JohnRR] #281103
04/08/09 10:34 AM
04/08/09 10:34 AM
I could use all 5 that I have pictured,
Ill look and see if I can find JUST a gasket set, but the rebuild kit is like $50.00 I dont need the other stuff..
the carb is new and it got some stuff past the bad filter and the car started running bad so I had to take it all apart to clean out the carb and those little gaskets pulled apart a little, everything else is fine.
what happened to the $10-$15 rebuild kits I use to sell at the auto parts store Ron...
Re: where to get the small gaskets in a edelbrock carb [Re: Mopar Ron] #281104
04/08/09 10:52 AM
04/08/09 10:52 AM
well I found a better price for just the gasket kit. $8.95 from summit but they have like a $11.00 "HANDLING" charge I'll keep checking around....
Re: where to get the small gaskets in a edelbrock carb [Re: Mopar Ron] #281105
04/08/09 11:14 AM
04/08/09 11:14 AM
I am going to trim some out myself. I have to know
Re: where to get the small gaskets in a edelbrock carb [Re: Mopar Ron] #281106
04/08/09 11:17 AM
04/08/09 11:17 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Re: where to get the small gaskets in a edelbrock carb [Re: Mopar Ron] #281107
04/08/09 11:53 AM
04/08/09 11:53 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
any Napa/Carquest/etc should be able to order it....might be a little more than $9, but definitely less than $20.
2017 Grand Cherokee Overland
Re: where to get the small gaskets in a edelbrock carb [Re: Mopar Ron] #281108
04/08/09 11:55 AM
04/08/09 11:55 AM
Staten Island, NY
RO23dave Offline
RO23dave  Offline
Staten Island, NY
i use carters myself and felt the same way. i found a little carb shop, upstate ny that stocks every known & unknown obscure carb gasket you can think of. call the guys at County Carburetor, Inc., 208 N. Hamilton St., Poughkeepsie, NY 12601. phone #845-452-6490, fax #845-454-2936. make a real time photocopy of your gaskets & fax to them. no need to buy complete kits and they don't kill you on the price. dave ss/ea #1355
Re: where to get the small gaskets in a edelbrock carb [Re: patrick] #281109
04/08/09 12:06 PM
04/08/09 12:06 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
How about Amazon, 8.95 and eligible for free shipping.
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps&field-keywords=edelbroock+1472
Re: where to get the small gaskets in a edelbrock carb [Re: ZIPPY] #281110
04/08/09 02:40 PM
04/08/09 02:40 PM
I have soaked them in WD-40 for a while and they wont stick when R&R them
I also do this to the 8 3/4 chunk gasket,and 9 1/4 cover gasket
done this on a bunch of chivy Q-jets and other carbs that need to be opend often
Re: where to get the small gaskets in a edelbrock carb [Re: scratchnfotraction] #281111
04/08/09 03:29 PM
04/08/09 03:29 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
$8.95 + $4.95 = $13.90 plus tax
Or you could buy 2 for $22.85 plus tax
Summit Shipping Charges.
Delivery and Handling
Delivery and handling on all domestic orders (including APO/FPO) is non- refundable and based on your order subtotal. It's a big benefit to buy everything at once (delivery and handling is a lot cheaper than actual shipping costs), but you can't plan for emergencies, so the cost is lower for smaller orders.
$0.00-$24.99 $4.95
$25.00-$99.99 $9.95
$100.00 and up $11.95
