While I have my rear axel torn down, I'd like to freshen everything up and try to rectify an issue that I noticed.
I need to know WTB or part numbers for the following two things:
- I have the sealed Green axel bearings. These have an O-ring that seals them to the housing. The O-rings look OK but they have seen better days. Can these be bought separately from the bearing kit?
- I need slightly longer housing studs (3/8"-24). Mine appear to be the normal 1-1/4" length. Can these be purchased in a 1-1/2" length by chance?
My setup is not OEM as I have the SSBC rear disc brakes and green bearings. Any help is appreciated!
