WTB - Green Bearing O-Ring/Longer Housing Studs #2809820
08/17/20 03:46 PM
08/17/20 03:46 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
While I have my rear axel torn down, I'd like to freshen everything up and try to rectify an issue that I noticed.
I need to know WTB or part numbers for the following two things:
- I have the sealed Green axel bearings. These have an O-ring that seals them to the housing. The O-rings look OK but they have seen better days. Can these be bought separately from the bearing kit?
- I need slightly longer housing studs (3/8"-24). Mine appear to be the normal 1-1/4" length. Can these be purchased in a 1-1/2" length by chance?
My setup is not OEM as I have the SSBC rear disc brakes and green bearings. Any help is appreciated! thumbs
Re: WTB - Green Bearing O-Ring/Longer Housing Studs [Re: cjskotni] #2809841
08/17/20 05:01 PM
08/17/20 05:01 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
If you can get good dimensions off the o-ring an industrial supply house should be able to hook you up. Maybe check the Dorman book for longer studs with the same knurl as your existing parts. drive
Re: WTB - Green Bearing O-Ring/Longer Housing Studs [Re: bobby66] #2809852
08/17/20 05:30 PM
08/17/20 05:30 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Yeah I can order the o-rings from McMaster but then I have to get like 50. Seems like a waste.
I checked Dorman and it seems they only sell wheel studs - not the housing studs I need. frown
Re: WTB - Green Bearing O-Ring/Longer Housing Studs [Re: cjskotni] #2809934
08/17/20 09:00 PM
08/17/20 09:00 PM
Make sure and use a good thread sealer around the serations, splines, on your new studs up
I've had stock lower ones leak after being accidently knock back into the housing when R&Ring third members whiney
The OEM soft copper washers stop that from the factory, if you don't reuse them make sure and use a good flat washer under the nuts and some good sealer between the washer and third member up wrench grin
Re: WTB - Green Bearing O-Ring/Longer Housing Studs [Re: Cab_Burge] #2810122
08/18/20 10:48 AM
08/18/20 10:48 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
When I did my Dana 60 I believe I got the T-bolts from Wilwood. They were long enough to work with my Wilwood disc brake brackets and green bearings.
68 Barracuda Formula S 340
