Is it possible to insulate a roll up door?
#2809444
08/16/20 11:36 AM
08/16/20 11:36 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Anyone done it? Any crazy ideas or thoughts from anyone who hasn't done it but has thought deep thoughts about it?
I need to start work on insulating my metal frame shop. And one of the biggest heat sources is the uninsulated roll up door that gets full sun. Is there a thin form of flexible sheet insulation I can attach to the inside if the door so that it rolls up with the door? The walls of shop currently have thin bubble wrap style insulation which I'm not sure actually helps.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Is it possible to insulate a roll up door?
[Re: Michael Ecks]
#2809471
08/16/20 12:47 PM
08/16/20 12:47 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
You mean like this commercial type? I don't think so. If you have a conventional type home owners door then yes as described above. I've seen a youtube howto on it.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: moparjim79]
#2809562
08/16/20 07:03 PM
08/16/20 07:03 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Depending on what type of roll up, yes. Ive seen the segmented(rectangular) roll ups with 1" high density foam adhered to it, and was told it was the most effective measure besides buying an insulated door($$$) I've had a couple friends wo did this. When I built my shop the salesman at the lumber company where I bought all my materials made me a great deal on insulated steel overhead doors.
[Re: 3hundred]
#2809575
08/16/20 08:03 PM
08/16/20 08:03 PM
Posts: 1,408 Central Pa
moparjim79
Central Pa
Think again. Yes that type of roll up steel door. It was a transportation terminal/repair facility I worked in.
[Re: Michael Ecks]
#2809631
08/17/20 12:03 AM
08/17/20 12:03 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Good question. Not sure of any great solutions. However have you regardless tried all the normal improvements, like a very white outside paint, awning shade for hottest part of the day, reduce reflection from outside ground surface, a lightweight insulating sliding curtain either inside or outside, if door only sees occasional use, , etc?
