Is it possible to insulate a roll up door? #2809444
08/16/20 11:36 AM
08/16/20 11:36 AM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
Anyone done it? Any crazy ideas or thoughts from anyone who hasn't done it but has thought deep thoughts about it?
I need to start work on insulating my metal frame shop. And one of the biggest heat sources is the uninsulated roll up door that gets full sun. Is there a thin form of flexible sheet insulation I can attach to the inside if the door so that it rolls up with the door? The walls of shop currently have thin bubble wrap style insulation which I'm not sure actually helps.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Is it possible to insulate a roll up door? [Re: Michael Ecks] #2809454
08/16/20 11:59 AM
08/16/20 11:59 AM
New Jersey
Dartforforty Offline
New Jersey
I have used this as an insulator, but not on a roll up door.
https://www.lowes.com/pd/Reflectix-...ll-Insulation-48-in-W-x-100-ft-L/3775465
Re: Is it possible to insulate a roll up door? [Re: Dartforforty] #2809463
08/16/20 12:30 PM
08/16/20 12:30 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Depending on what type of roll up, yes. Ive seen the segmented(rectangular) roll ups with 1" high density foam adhered to it, and was told it was the most effective measure besides buying an insulated door($$$)
Re: Is it possible to insulate a roll up door? [Re: Michael Ecks] #2809471
08/16/20 12:47 PM
08/16/20 12:47 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
You mean like this commercial type? I don't think so. If you have a conventional type home owners door then yes as described above. I've seen a youtube howto on it.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Is it possible to insulate a roll up door? [Re: Michael Ecks] #2809518
08/16/20 04:05 PM
08/16/20 04:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Is it possible to insulate a roll up door? [Re: moparjim79] #2809562
08/16/20 07:03 PM
08/16/20 07:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've had a couple friends wo did this. When I built my shop the salesman at the lumber company where I bought all my materials made me a great deal on insulated steel overhead doors.
Re: Is it possible to insulate a roll up door? [Re: 3hundred] #2809575
08/16/20 08:03 PM
08/16/20 08:03 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Think again. Yes that type of roll up steel door. It was a transportation terminal/repair facility I worked in.
Re: Is it possible to insulate a roll up door? [Re: Michael Ecks] #2809631
08/17/20 12:03 AM
08/17/20 12:03 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Good question. Not sure of any great solutions. However have you regardless tried all the normal improvements, like a very white outside paint, awning shade for hottest part of the day, reduce reflection from outside ground surface, a lightweight insulating sliding curtain either inside or outside, if door only sees occasional use, , etc?
Re: Is it possible to insulate a roll up door? [Re: jcc] #2809656
08/17/20 07:09 AM
08/17/20 07:09 AM
Unfortunately back in New York
N
Nukechargerboy Offline
N
Try calling the manufacturer and see if they have a kit for the door.
Re: Is it possible to insulate a roll up door? [Re: Nukechargerboy] #2809784
08/17/20 02:28 PM
08/17/20 02:28 PM
GA
roadrunninMark Online sick
roadrunninMark  Online Sick
GA
What about covering it with some sort of insulation paint, like Lizard Skin? Just don't paint the joints but the flats I think it would work?
