Solid FT Lifter Weight #2808754
08/14/20 09:08 AM
08/14/20 09:08 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
When choosing a 340 solid flat tappet lifter, when do the lighter weight lifters become required?
Example: 101g versus the 79g lifters.
Re: Solid FT Lifter Weight [Re: YO7_A66] #2809196
08/15/20 12:01 PM
08/15/20 12:01 PM
God's Country Maryland
GODSCOUNTRY340 Offline
The higher the RPMs the engine sees, the lighter you want your lifters. Heavy lifters will overpower your valve springs sooner in the RPM range than light lifters. If you're going to exceed 6,500 RPMs, use the light lifters.
Re: Solid FT Lifter Weight [Re: GODSCOUNTRY340] #2809223
08/15/20 01:02 PM
08/15/20 01:02 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am planning on being in the 62-6400 range max.
Thank you!
Re: Solid FT Lifter Weight [Re: GODSCOUNTRY340] #2809357
08/16/20 12:31 AM
08/16/20 12:31 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
So let me pose this another way
Would there ever be a benefit to using a heavier lifter?
(everything ive ever read says no?)
