08/11/20 02:41 AM
08/11/20 02:41 AM
MD
HEMI472 Offline OP
HEMI472  Offline OP
MD
hello i have a 727 in my 68 dart with the drive shaft on the car you can hardly push the car by hand but you take the drive shaft off you can push it with one finger. why is it so hard to push with drive shaft on ???????
Re: 727 [Re: HEMI472] #2807552
08/11/20 07:11 AM
08/11/20 07:11 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Fresh rebuild?.
They can be tight, but that seems excessive.
Trans. car details?
New problem or 1st you noticed?
Seized rear support....?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 727 [Re: HEMI472] #2807604
08/11/20 10:22 AM
08/11/20 10:22 AM
The Great State of PA
tabletop390 Offline
tabletop390  Offline
My experience when it's been something like that is either the drums aren't aligned and seated properly in the sun bell, or a sprag issue. You didn't say if you've been running it this way or not. Usually when it's screwed up like that, you get 3rd gear and reverse.
Re: 727 [Re: tabletop390] #2807636
08/11/20 11:53 AM
08/11/20 11:53 AM
MD
HEMI472 Offline OP
HEMI472  Offline OP
MD
every thing works fine . been in the car for years . you just cant push it very easy. shifter works fine and is going fully in neutral. fluid is red looks like new .
Re: 727 [Re: HEMI472] #2807637
08/11/20 12:00 PM
08/11/20 12:00 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
My cars the same way .
I never really worried about it .
Re: 727 [Re: HEMI472] #2807645
08/11/20 12:12 PM
08/11/20 12:12 PM
AndyF Online content
AndyF  Online Content
My car is also very difficult to push and if it is in the air the tires are hard to rotate. But the transmission pan is clean and it drives fine down the road. All gears work like they should. I think there is just a lot of friction inside a fresh 727.
Re: 727 [Re: HEMI472] #2807685
08/11/20 01:31 PM
08/11/20 01:31 PM
Something is amiss, I fear scope
All the good race 727 I've owned and race would push backwards harder than forward but none of them did what your talking labout work
It is talking to you, now is the time to find out what it is causing that twocents
Re: 727 [Re: HEMI472] #2807692
08/11/20 01:40 PM
08/11/20 01:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's normal for the car to push harder backward than forward but hard to push in both directions points to tight clutch/band clearances. This won't noticeably effect the operation of the trans.
Re: 727 [Re: HEMI472] #2807703
08/11/20 02:05 PM
08/11/20 02:05 PM
South Lyon, Michigan
6bblRoadrunner Offline
Have you tried removing the driveshaft and testing? Rule out the rear brakes and a bent housing. Just a thought.
Re: 727 [Re: 6bblRoadrunner] #2807803
08/11/20 06:27 PM
08/11/20 06:27 PM
Me thinks he did that already scope grin
Re: 727 [Re: Cab_Burge] #2807848
08/11/20 08:44 PM
08/11/20 08:44 PM
You’re right. Don’t know how I missed that.
Re: 727 [Re: 6bblRoadrunner] #2807923
08/12/20 02:06 AM
08/12/20 02:06 AM
MD
HEMI472 Offline OP
HEMI472  Offline OP
MD
yes i checked it with the drive shaft out . the trans works great but i guess i just noticed it was hard to push with just me pushing it by hand thanks
Re: 727 [Re: HEMI472] #2808070
08/12/20 12:36 PM
08/12/20 12:36 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
Your just getting old.
America First!
Re: 727 [Re: carnut68] #2808150
08/12/20 04:23 PM
08/12/20 04:23 PM
If YOU live long enough you will get OLD also work stirthepot grin
Nothing wrong with living a good, long life up twocents grin
