Vinyl roof car or no? #2807135
08/10/20 01:52 AM
08/10/20 01:52 AM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
I can not tell but was told it was? Fender tag shows nada!
thx Diego
Re: Vinyl roof car or no? [Re: Diego_Ted] #2807136
08/10/20 01:54 AM
08/10/20 01:54 AM
Diego-Town, CA
Diego-Town, CA
tag
Re: Vinyl roof car or no? [Re: Diego_Ted] #2807187
08/10/20 10:02 AM
08/10/20 10:02 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Looks like a '65 Satellite, shows up on my monitor like D, the light blue metallic.
FT says K, light turquoise metallic; can't quite make out interior code, is that B, like blue ?
I'm going by memory on those codes, correct me if I'm wrong.
But to answer the question, looks like glue residue on roof.
VT could have been added, not sure of they were called out on FT in that period, that was early days for VT.
Re: Vinyl roof car or no? [Re: topside] #2807237
08/10/20 11:58 AM
08/10/20 11:58 AM
Diego-Town, CA
Diego-Town, CA
Yes 65 Satellite, color outside is wrong, yes it's a KK1 light turquoise metallic, TRM=P4Q. Yes there is glue up top. So did Vinyl and non Vinyl have the same roof trim? I am wondering if the factory offered a Vinyl top? Non of the big makers seem to sell a replacement? There is only one offering a vinyl top and it has no padding underneath?
thx Diego
Re: Vinyl roof car or no? [Re: Diego_Ted] #2807267
08/10/20 01:09 PM
08/10/20 01:09 PM
A collage of whims
A collage of whims
All the '65 Satellites I've ever seen had the same roof moldings; the wide drip rail moldings were Satellite only.
Might be a color & trim guide and option info at hamtramck-historical.
I've seen one with VT but that was long ago and I don't know if it was factory or added later.
Another clue might be to see if there are different #s in a '65 parts book for satellite with or without VT.
No padding under VT until much later, like later '70s disco-era stuff.
Re: Vinyl roof car or no? [Re: topside] #2807292
08/10/20 02:14 PM
08/10/20 02:14 PM
5thAve Offline
5thAve  Offline
Usually when it had a vinyl roof there was stuff left unfinished underneath them. Can't tell from the picture if it's glue residue or dirt like the rest of the car has.
Re: Vinyl roof car or no? [Re: 5thAve] #2807567
08/11/20 07:39 AM
08/11/20 07:39 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
If you pull the window trim off the front or back there could be some top material left behind if it is a vinyl top car.
Re: Vinyl roof car or no? [Re: maximus] #2807578
08/11/20 08:48 AM
08/11/20 08:48 AM
GMP440 Offline
GMP440  Offline
Also, want to add if you do pull the trim off , look to see if there are any staples left in there. Chrysler used staples to fasten the edges of the vinyl top into those channel areas behind the trim.
