Re: Vinyl roof car or no?
[Re: Diego_Ted]
#2807187
08/10/20 10:02 AM
08/10/20 10:02 AM
Posts: 20,987 A collage of whims
topside
A collage of whims
Looks like a '65 Satellite, shows up on my monitor like D, the light blue metallic. FT says K, light turquoise metallic; can't quite make out interior code, is that B, like blue ? I'm going by memory on those codes, correct me if I'm wrong. But to answer the question, looks like glue residue on roof. VT could have been added, not sure of they were called out on FT in that period, that was early days for VT.
[Re: topside]
#2807237
08/10/20 11:58 AM
08/10/20 11:58 AM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
Yes 65 Satellite, color outside is wrong, yes it's a KK1 light turquoise metallic, TRM=P4Q. Yes there is glue up top. So did Vinyl and non Vinyl have the same roof trim? I am wondering if the factory offered a Vinyl top? Non of the big makers seem to sell a replacement? There is only one offering a vinyl top and it has no padding underneath?
thx Diego
[Re: maximus]
#2807578
08/11/20 08:48 AM
08/11/20 08:48 AM
Posts: 1,645 Florida
GMP440
If you pull the window trim off the front or back there could be some top material left behind if it is a vinyl top car. Also, want to add if you do pull the trim off , look to see if there are any staples left in there. Chrysler used staples to fasten the edges of the vinyl top into those channel areas behind the trim.
