Re: silver sport A41 transmission
[Re: DirectConnection]
#2807093
08/09/20 10:37 PM
08/09/20 10:37 PM
Posts: 18,160 Mass
DAYCLONA
Mass
I've done the 71 B body install, nice kit, I'll assume your going/using floor shifter?... the tranny is cable shifted, you can use the stock shifter but you have to modify it with the supplied components to detente 4 forward shift positions, kick down linkage gets replaced with a TV cable, the kit is supplied with braided SS tranny lines for cooling, as they exit on the passenger side of the tranny, no floor work was required in the 71 B body application, I would assume no floor mods for the 2nd gen B body as the A41 tranny is rather narrow, more so than the 727 case, pretty much a bolt in kit, with minor mods....what's your current HP/torque?
#2807507
08/10/20 10:55 PM
08/10/20 10:55 PM
Posts: 18,160 Mass
DAYCLONA
Mass
last time on the chassis dyno 440 hp at the wheels will have to go back and check the torque but would go for the 650 torque model floor shifter could my b and m z gate shifter work
Yes, Stage 3 no question if your at 440 hp at the rear wheels.... As far as the B&M if it's an older model (3spd) I don't know if B&M offers upgrade components, but B&M offers a new line of AOD shifters
#2808249
08/12/20 10:07 PM
08/12/20 10:07 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Apples and oranges here but I did an AT conversion to the Tremec five speed in my ‘72 Charger. SST was a pleasure to work with, the Kit was awesome, the instructions worked well. It was radical surgery so there were a couple of issues and SST came through without any drama. It was a HUGE “trigger” to pull for me but I have absolutely no regrets. It probably saved me from selling the car.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
