Dana Axles with sealed bearings #2806506
08/08/20 10:57 AM
08/08/20 10:57 AM
Danville, NH
Mopar_Mike Online content OP
Mopar_Mike  Online Content OP
Danville, NH
I am putting my 67 Dana 60 back together and using sealed pressed on bearings on the axles. Do I still need to worry about axle play and adjustment? Thanks
RS23L7 4-Speed
Re: Dana Axles with sealed bearings [Re: Mopar_Mike] #2806533
08/08/20 11:48 AM
08/08/20 11:48 AM
Have you removed the end play adjuster from the posi unit ?
If not I would and go from there wrench
You do not want the axles to have any preload on them with both axles installed in the housing with either type of the "green ball bearing type" axle bearings tsk
So yes you should have a small amount of end play, say from .003 to .015 scope
Re: Dana Axles with sealed bearings [Re: Cab_Burge] #2806553
08/08/20 12:54 PM
08/08/20 12:54 PM
Danville, NH
Danville, NH
Not sure.. not sure it was and not sure where it is?
RS23L7 4-Speed
Re: Dana Axles with sealed bearings [Re: Mopar_Mike] #2806555
08/08/20 01:07 PM
08/08/20 01:07 PM
Danville, NH
Danville, NH
I have both axles out the original bearings were replaced with the sealed green style I want to put the axles back in but not sure about those thrust washers? I’m reading eight and three-quarter and Dana have different length ones which can cause end play problems but I don’t see any in this rear end so I’m thinking I’ll have all sorts of problems if I just put the axles in and bolt them in. I got the Dana With the car but it was out and although the axles where installed I wanted to pull them and make sure everything was ok. I’m pretty sure this was done before I got it as the bearings are new but I know the car/rear wasn’t in use
RS23L7 4-Speed
Re: Dana Axles with sealed bearings [Re: Mopar_Mike] #2806597
08/08/20 03:19 PM
08/08/20 03:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the Green bearings have a snap ring (MO-400), they can be installed with no other modifications. If the bearings have an attached flange, maybe not.
Re: Dana Axles with sealed bearings [Re: John_Kunkel] #2806602
08/08/20 03:29 PM
08/08/20 03:29 PM
Danville, NH
Danville, NH
The adjuster is off the RH axle, Cab had me confused about an adjustment on the center section? Cab, do you mean the thrust block? If I can see clear from one end to and through the other end of the housing there should be no thrust block there? correct?
RS23L7 4-Speed
Re: Dana Axles with sealed bearings [Re: Mopar_Mike] #2806606
08/08/20 03:42 PM
08/08/20 03:42 PM
All the early Mopar posi rear ends, pre mid 1969 8 3/4 ,and all the Dana 60 Mopar posi rear ends I've seen have seen had a pair of plugs, slugs( I don't know the proper name for them blush) in the center of the cross shafts that was used to set the end play on the axles .Thrust blocks sounds correct, I'm going to ASSUME yours are missing now so you MAY be good luck
Re: Dana Axles with sealed bearings [Re: Cab_Burge] #2806618
08/08/20 04:27 PM
08/08/20 04:27 PM
Danville, NH
Danville, NH
We are on the same page Cab, thanks. Although something is definitely wrong though.. I put gasket, backing plate, white foam gasket and then axle with retaining plate tightened all five nuts. Have about 1/4" plus play on both sides and also was able to just pull the axle right out..
RS23L7 4-Speed
Re: Dana Axles with sealed bearings [Re: Mopar_Mike] #2806629
08/08/20 05:00 PM
08/08/20 05:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Are you saying you can pull the axle out of the bearing or the axle with bearing? There is a snap ring around the bearing that the retaining plate contacts to keep the bearing in place, is it there?.
Re: Dana Axles with sealed bearings [Re: Mopar_Mike] #2806631
08/08/20 05:02 PM
08/08/20 05:02 PM
Sounds like the axle bearings you got are not the proper O.D. for your retaining plates and the axle housing work scope
Re: Dana Axles with sealed bearings [Re: John_Kunkel] #2806638
08/08/20 05:19 PM
08/08/20 05:19 PM
Danville, NH
Danville, NH
Ah ha! Yes John, there isn’t a snap ring around the bearing. So the axle with the bearing attached just pulls through the retainer. Thanks for the pic
RS23L7 4-Speed
Re: Dana Axles with sealed bearings [Re: Mopar_Mike] #2806647
08/08/20 05:36 PM
08/08/20 05:36 PM
Danville, NH
Danville, NH
Now, any idea where I can get two? Lol
RS23L7 4-Speed
Re: Dana Axles with sealed bearings [Re: Mopar_Mike] #2806717
08/08/20 11:15 PM
08/08/20 11:15 PM
Call Cass at Dr. Diff. He owns and operates Quality Body Shop. 406-883-4772 scope
