Measuring pinion angle Dana 60 #2804757
08/03/20 08:32 PM
08/03/20 08:32 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I am having a hard time measure the angle of the rear end.
Can I use the flange on the side as in photo?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Measuring pinion angle Dana 60 [Re: Kam*Kuda] #2804761
08/03/20 08:37 PM
08/03/20 08:37 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
needs to be off the ujoint cap
Re: Measuring pinion angle Dana 60 [Re: CSK] #2804765
08/03/20 08:52 PM
08/03/20 08:52 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Driveshaft is 1.2 degrees
rear end is 1.0 degrees on the yoke
1654.5 Mustang
1955 Land Rover
Re: Measuring pinion angle Dana 60 [Re: Kam*Kuda] #2804769
08/03/20 08:57 PM
08/03/20 08:57 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Whats the trans & is that a 4 link set up ?
up,down ? rear looks up
Re: Measuring pinion angle Dana 60 [Re: CSK] #2804785
08/03/20 09:46 PM
08/03/20 09:46 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
727 Trans Ladder Bar set up
I just moved the front hole up and need to adjust the pinion angle down
Can I shorten the bottoms ?
or do I need to extend the top?
1654.5 Mustang
1955 Land Rover
Re: Measuring pinion angle Dana 60 [Re: Kam*Kuda] #2804799
08/03/20 10:27 PM
08/03/20 10:27 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I use the cover on the back, really we just eyeballed it and forgot about it. One is always going to be off, rear, driveshaft or trans so the point is moot, it moves
Re: Measuring pinion angle Dana 60 [Re: Kam*Kuda] #2804814
08/03/20 10:49 PM
08/03/20 10:49 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
driveshaft is up 0.5
rear is down 1.2
How does that look?
1654.5 Mustang
1955 Land Rover
Re: Measuring pinion angle Dana 60 [Re: Kam*Kuda] #2804817
08/03/20 11:02 PM
08/03/20 11:02 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Make the pinion center-line parallel to the transmission center-line.
Re: Measuring pinion angle Dana 60 [Re: Kam*Kuda] #2804949
08/04/20 10:58 AM
08/04/20 10:58 AM
AndyF Offline
AndyF  Offline
If it was correct before you moved the front up then just adjust the bars to put the pinion back at the same angle. Shouldn't require anything more than a tape measure to do that since you had a fixed location to work from.
Re: Measuring pinion angle Dana 60 [Re: Kam*Kuda] #2804969
08/04/20 11:30 AM
08/04/20 11:30 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'm not a ladder bar guy so please pardon my ignorance. Won't either of these adjustments raise the yoke and increase the pinion angle?
Re: Measuring pinion angle Dana 60 [Re: justinp61] #2805040
08/04/20 02:43 PM
08/04/20 02:43 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Lengthen the link in the ladder bar will roll the housing around and point the pinion lower. (angle from positive to negative)
To measure the pinion angle, rotate the pinion to get the yoke to where the u joint caps/U bolts are at 3 and 9 o'clock and lay your angle finder on the front flat of the yoke beside the U-bolt. Or lay the angle finder on the heads of the cover bolts on either side of the cover. Subtract to 90* difference.
Not going to get into how to figure what it should be today, except to say I avoid positive rear u-joint operating angle at all costs which goes against some of the other methods. On a big tire, backhalf, stock front ride height car, you have to compromise sometimes.
