Measuring pinion angle Dana 60
#2804757
08/03/20 08:32 PM
08/03/20 08:32 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
I am having a hard time measure the angle of the rear end. Can I use the flange on the side as in photo?
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: Measuring pinion angle Dana 60
[Re: Kam*Kuda]
#2804761
08/03/20 08:37 PM
08/03/20 08:37 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
needs to be off the ujoint cap
[Re: CSK]
#2804765
08/03/20 08:52 PM
08/03/20 08:52 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
Driveshaft is 1.2 degrees rear end is 1.0 degrees on the yoke
[Re: Kam*Kuda]
#2804769
08/03/20 08:57 PM
08/03/20 08:57 PM
CSK
Pattison Texas
Driveshaft is 1.2 degrees rear end is 1.0 degrees on the yoke Whats the trans & is that a 4 link set up ? up,down ? rear looks up
[Re: CSK]
#2804785
08/03/20 09:46 PM
08/03/20 09:46 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
727 Trans Ladder Bar set up
I just moved the front hole up and need to adjust the pinion angle down
Can I shorten the bottoms ? or do I need to extend the top?
[Re: Kam*Kuda]
#2804814
08/03/20 10:49 PM
08/03/20 10:49 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
driveshaft is up 0.5
rear is down 1.2
How does that look?
[Re: Kam*Kuda]
#2804949
08/04/20 10:58 AM
08/04/20 10:58 AM
Posts: 31,046 Oregon
AndyF
Can I shorten the bottoms ? or do I need to extend the top? If it was correct before you moved the front up then just adjust the bars to put the pinion back at the same angle. Shouldn't require anything more than a tape measure to do that since you had a fixed location to work from.
[Re: Kam*Kuda]
#2804969
08/04/20 11:30 AM
08/04/20 11:30 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Can I shorten the bottoms ? or do I need to extend the top? I'm not a ladder bar guy so please pardon my ignorance. Won't either of these adjustments raise the yoke and increase the pinion angle?
[Re: justinp61]
#2805040
08/04/20 02:43 PM
08/04/20 02:43 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Lengthen the link in the ladder bar will roll the housing around and point the pinion lower. (angle from positive to negative)
To measure the pinion angle, rotate the pinion to get the yoke to where the u joint caps/U bolts are at 3 and 9 o'clock and lay your angle finder on the front flat of the yoke beside the U-bolt. Or lay the angle finder on the heads of the cover bolts on either side of the cover. Subtract to 90* difference.
Not going to get into how to figure what it should be today, except to say I avoid positive rear u-joint operating angle at all costs which goes against some of the other methods. On a big tire, backhalf, stock front ride height car, you have to compromise sometimes.
