Torque converter help #2803410
07/31/20 07:11 PM
07/31/20 07:11 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Installing new converter into 727 and measurement is 1-1/8 from ring gear to bellhousing at the bottom , old converter measures 1-1/4 can't get the new one in any further , should that cause a problem being 1/8 out , want to be sure before putting in and have to take it back out .
Re: Torque converter help [Re: 426lloyd] #2803418
07/31/20 07:20 PM
07/31/20 07:20 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Another measurement used is making sure after klunking far enough back, that if you placed a straightedge across face of bell-trans housing, then measured back to face of one of the converter mounting bolt pads, that there is at least 1/2" space between, you know an air gap.
Re: Torque converter help [Re: 426lloyd] #2803422
07/31/20 07:28 PM
07/31/20 07:28 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Measure the flexplate on the back of the engine.I believe my flexplate was .400" off the enging on the vert side.The ring gear was 1"
Re: Torque converter help [Re: buildanother] #2803426
07/31/20 07:39 PM
07/31/20 07:39 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Ok just put a straight edge across the front and it measured exactly 1/2 inch to the face of pad , converter seems bottomed out so I should be good to go correct .
Re: Torque converter help [Re: 426lloyd] #2803448
07/31/20 08:34 PM
07/31/20 08:34 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Looks good with .100" to the fp to pull forward when all together
Re: Torque converter help [Re: Clanton] #2803453
07/31/20 08:42 PM
07/31/20 08:42 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Ok thank you
Re: Torque converter help [Re: 426lloyd] #2803666
08/01/20 11:38 AM
08/01/20 11:38 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The shape of the converter bowl determines when/where it bottoms out. The 1/2" drive lug dimension is all that matters.
