Re: Torque converter help
[Re: 426lloyd]
#2803422
07/31/20 07:28 PM
07/31/20 07:28 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Installing new converter into 727 and measurement is 1-1/8 from ring gear to bellhousing at the bottom , old converter measures 1-1/4 can't get the new one in any further , should that cause a problem being 1/8 out , want to be sure before putting in and have to take it back out . Measure the flexplate on the back of the engine.I believe my flexplate was .400" off the enging on the vert side.The ring gear was 1"
[Re: 426lloyd]
#2803448
07/31/20 08:34 PM
07/31/20 08:34 PM
Clanton
northern,Ohio,USA
Ok just put a straight edge across the front and it measured exactly 1/2 inch to the face of pad , converter seems bottomed out so I should be good to go correct . Looks good with .100" to the fp to pull forward when all together
[Re: 426lloyd]
#2803666
08/01/20 11:38 AM
08/01/20 11:38 AM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Ok just put a straight edge across the front and it measured exactly 1/2 inch to the face of pad , converter seems bottomed out so I should be good to go correct . The shape of the converter bowl determines when/where it bottoms out. The 1/2" drive lug dimension is all that matters.
