Page 1 of 4 1 2 3 4
Dyno day tomorrow! #2802494
07/29/20 12:40 PM
07/29/20 12:40 PM
gregsdart Offline OP
My 550 cube 440-1 headed, alky injected motor is going to get broken in this afternoon and then tuning is planned for tomorrow Am.
Line2line piston coatings take a number of heat cycles to wear in to the proper fit. So we will burn up some fuel ! Results later!
Re: Dyno day tomorrow! [Re: gregsdart] #2802525
07/29/20 01:42 PM
07/29/20 01:42 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
up nice!!
I hope it all goes well!!
What did it make last time it was on the dyno?
Re: Dyno day tomorrow! [Re: gregsdart] #2802530
07/29/20 01:58 PM
07/29/20 01:58 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Do you have a leanout valve on the injection?
Re: Dyno day tomorrow! [Re: Clanton] #2802541
07/29/20 02:20 PM
07/29/20 02:20 PM
tboomer Online work
tboomer  Online Work
Good luck Greg! up
Re: Dyno day tomorrow! [Re: gregsdart] #2802575
07/29/20 03:55 PM
07/29/20 03:55 PM
NC
440Jim Offline
440Jim  Offline
NC
I look forward to the dyno results.
Let's see what the 550 cubes do compared to the previous version.
It gets tough to make HP above 900, IMO;
So I am guessing 899 this time.
My notes on your combo:
Quote
From 4.15 stroke x 4.500 bore and 528 cubes, new combo is 4.315 stroke and 4.5043 bore for 550 cubes.
Same heads, 440-1 ported with 2.30x1.78 valves, 3x intake, 284/296/114 duration cam with .870 gross intake lift and about .810 exhaust. The intake flow is 390, Exhaust is 294.
CR was 13.56/1. The new combo with 550 cubes it will have 14.972/1
Plus the dyno service has 2-1/4 headers which may make more power than my 2-1/8
Way back in 03 it made 847 hp and that was without decent vacuum. Only pulled 1.5 inch. Different dyno.
Re: Dyno day tomorrow! [Re: tboomer] #2802578
07/29/20 03:56 PM
07/29/20 03:56 PM
New York, USA
Chargerfan68 Offline
New York, USA
Good luck. Hope it goes great. Is there a support group for guys addicted to dynoing? Haha. I’m now one of the victims.
Re: Dyno day tomorrow! [Re: Chargerfan68] #2802646
07/29/20 07:58 PM
07/29/20 07:58 PM
Thanks guys! Things went great and i got the coated pistons broke in properly so we had time to make some pulls!
OK, what do you all think it made? I will post the best pull in two hours. 8pm central time.
It made 847 hp last time (2003!) But less cam, less compression, 2 inch dyno headers.
This time 2 1/4 headers and increase from 2.25 intakes to 2.300. Cam went from 278/290/110 to 284/296/114 and .100 more lift. Better oil pan. Over 1 point compeession increase to 15.1..
Re: Dyno day tomorrow! [Re: gregsdart] #2802652
07/29/20 08:32 PM
07/29/20 08:32 PM
New York, USA
New York, USA
I hope i’m low, but i’m going to guess 890 hp. I hope you break the 900 mark. You have alot of positive changes, so maybe you will. Best of luck.
Re: Dyno day tomorrow! [Re: Chargerfan68] #2802661
07/29/20 08:52 PM
07/29/20 08:52 PM
Well, here it is. I am happy!
Re: Dyno day tomorrow! [Re: gregsdart] #2802675
07/29/20 09:42 PM
07/29/20 09:42 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Very nice! Congrats!
Re: Dyno day tomorrow! [Re: gregsdart] #2802676
07/29/20 09:43 PM
07/29/20 09:43 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Id be pretty darn happy with that improvement, guess that could depend on dollars spent overall, but a substancial improvement.
Re: Dyno day tomorrow! [Re: markz528] #2802677
07/29/20 09:46 PM
07/29/20 09:46 PM
New York, USA
New York, USA
That’s totally awesome and impressive!! Very well done. Happy for you!
Re: Dyno day tomorrow! [Re: Chargerfan68] #2802678
07/29/20 09:55 PM
07/29/20 09:55 PM
Thanks Chargerfan. I was hoping for over 880 hp. To see another 46 hp , well, not many builds work out this well. I must have hit a real sweet spot where all the stars aligned!
Re: Dyno day tomorrow! [Re: gregsdart] #2802682
07/29/20 10:09 PM
07/29/20 10:09 PM
Thanks Markz and Wyoming!
Re: Dyno day tomorrow! [Re: gregsdart] #2802739
07/30/20 04:37 AM
07/30/20 04:37 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
I know nothing of engines at this level, but are those normal bsfc figures for this sort of monster? they look really high?
Might be some more tune left in it?
Re: Dyno day tomorrow! [Re: Alchemi] #2802743
07/30/20 07:08 AM
07/30/20 07:08 AM
[quote=Alchemi]I know nothing of engines at this level, but are those normal bsfc figures for this sort of monster? they look really high?
Might be some more tune left in it? [/quot
We made several pulls, adding fuel (methanol) each pull. It just kept making more power the more fuel we threw at it. The bsfc numbers said it was fat, but the power just kept going up. We finally hit a point where peak torque stayed the same.
This shows the value of dynoing a motor. I was certain i knew roughly where the tune should be. I had run a calculation on a web site that said a .117 main bypass would be close. I started at .108 and ended at .092! That means i pushed about 16 percent more fuel at it than my already supposedly rich point of .108.
Also we found and fixed oil leaks that could have cost me a weekend.
Without seeing the results of the unexpected high horse power at 7200, i could have chased the tuneup at the track and never figured it out because of false assumptions i had about what the motor wanted and how high it would make power.
Re: Dyno day tomorrow! [Re: gregsdart] #2802744
07/30/20 07:12 AM
07/30/20 07:12 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
Awesome. Going to the track soon?
Re: Dyno day tomorrow! [Re: 80arrow] #2802746
07/30/20 07:27 AM
07/30/20 07:27 AM
Hi Clint. I want to run the MSRA event on Aug 21-23 if possibe.
Re: Dyno day tomorrow! [Re: gregsdart] #2802749
07/30/20 07:34 AM
07/30/20 07:34 AM
tboomer Online work
tboomer  Online Work
Greg...Congrats! Mopar Max is at Cedar Falls that weekend..5 grand a day for the winner on Saturday and Sunday! wave
Re: Dyno day tomorrow! [Re: tboomer] #2802755
07/30/20 08:07 AM
07/30/20 08:07 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Very impressive! Congrats and thanks for sharing. It's funny? when a build using orig. B1 heads with similar flow is expected to make another 50HP.
Page 1 of 4 1 2 3 4
