Intake Manifold Id..?? #2801922
07/27/20 10:11 PM
07/27/20 10:11 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
IAnybody know anything about this intake? The casting number leads me to believe it's from the '60's but I can't find it listed anywhere. Note the big water fitting up front. The ports are roughly 1 7/8" tall. confused
20200727_130013_resized.jpg20200727_130027_resized.jpg20200727_105012_resized.jpg20200727_130152_resized.jpg
Re: Intake Manifold Id..?? [Re: vdriver] #2801927
07/27/20 10:28 PM
07/27/20 10:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Looks to be possibly an industrial application. Odd bosses and no coil mount. What does the choke well look like? No doubt it is a 67 or newer LA application.
Re: Intake Manifold Id..?? [Re: NITROUSN] #2801964
07/28/20 12:37 AM
07/28/20 12:37 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
A search on the casting number comes up with a "water heated intake manifold". Not sure of the application, though.
Re: Intake Manifold Id..?? [Re: Jim_Lusk] #2802042
07/28/20 09:33 AM
07/28/20 09:33 AM
scratchnfotraction Offline
it does have a coil mount.
never seen a pipe plug in that spot on a intake. if its in the cross over? or it could be an oil dump for an oil cooler if open to valley? definitely has a cast in boss for it.
water by pass fittings looks to be plumbed for Indust/boat engine with water cooled exhaust manifolds maybe.
looks to be an early non emissions 318 intake. it does have bosses for v style a/c comp. 273 had a single plane 2v intake so don't think it is 273. could be from larger Industrial truck app.
I agree 67 or newer
I wager a boat engine or larger truck chassis.
Re: Intake Manifold Id..?? [Re: scratchnfotraction] #2802101
07/28/20 11:39 AM
07/28/20 11:39 AM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
No choke well or EGR.
Re: Intake Manifold Id..?? [Re: vdriver] #2802162
07/28/20 02:49 PM
07/28/20 02:49 PM
IL
furious70 Offline
furious70  Offline
IL
With no choke provision then the application must have been industrial of some sort, not expected to go through frequent warm up cycles?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Intake Manifold Id..?? [Re: Jim_Lusk] #2802168
07/28/20 03:16 PM
07/28/20 03:16 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
1970 ~ 1978, interesting. Here's a pic of the different heads to go with it.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
