Re: Intake Manifold Id..??
[Re: Jim_Lusk]
#2802042
07/28/20 09:33 AM
07/28/20 09:33 AM
Posts: 15,487 Florida
scratchnfotraction
it does have a coil mount.
never seen a pipe plug in that spot on a intake. if its in the cross over? or it could be an oil dump for an oil cooler if open to valley? definitely has a cast in boss for it.
water by pass fittings looks to be plumbed for Indust/boat engine with water cooled exhaust manifolds maybe.
looks to be an early non emissions 318 intake. it does have bosses for v style a/c comp. 273 had a single plane 2v intake so don't think it is 273. could be from larger Industrial truck app.
I agree 67 or newer
I wager a boat engine or larger truck chassis.
[Re: vdriver]
#2802162
07/28/20 02:49 PM
07/28/20 02:49 PM
Posts: 2,256 IL
furious70
IL
With no choke provision then the application must have been industrial of some sort, not expected to go through frequent warm up cycles?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Jim_Lusk]
#2802168
07/28/20 03:16 PM
07/28/20 03:16 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
A search on the casting number comes up with a "water heated intake manifold". Not sure of the application, though. 1970 ~ 1978, interesting. Here's a pic of the different heads to go with it.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
