Re: throttle set up
[Re: John_Kunkel]
#2802128
07/28/20 01:13 PM
07/28/20 01:13 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
Re: throttle set up
[Re: ChrgrCuda]
#2802139
07/28/20 02:03 PM
07/28/20 02:03 PM
Posts: 19,659 north of coder
moparx
with a small block mopar from a duster. to the OP : i'm just having fun....... meant no disrespect. to get full throttle in your application, you may have to move the cable mount some, or change the arm of the carb ratio to cable hookup. a pic of your setup would help with seeing what needs done.
Re: throttle set up
[Re: duspan]
#2803203
07/31/20 09:25 AM
07/31/20 09:25 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
i have a stock gas peddle with a lokar cable and a crs holley 750 carb bracket for the cable and return spring on a 340 motor, in a 72 duster my problem is i can not get full throttle with this setup? i can only get 3/4 throttle? Ditch the POS Lokar, they are a PITA. I could never get mine sorted, I threw it in the trash at the track. I just used the spare stock unit I had in the box of parts. All I had to do was add a piece of coat hanger and problem solved.
Re: throttle set up
[Re: cudaman1969]
#2803282
07/31/20 01:08 PM
07/31/20 01:08 PM
moparx
Without a pic I’ll have to guess you have the cable in the Chevy hole. Chrysler pedal does not have enough travel, carb pivot has to be closer to the throttle shaft this is my thought as well. a picture of the OP's setup would go a long way in offering suggestions for a cure to his problem.
