throttle cable for T ram #2800669
07/24/20 03:40 PM
07/24/20 03:40 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
What kind of throttle cable you guys using for tunnel rams? This is what i have and not sure i can modify to work.
Re: throttle cable for T ram [Re: mopar dave] #2800677
07/24/20 04:37 PM
07/24/20 04:37 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
My Hilborn has the same set up, I used the same cable for the carb
Re: throttle cable for T ram [Re: CSK] #2800679
07/24/20 04:41 PM
07/24/20 04:41 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, thanks. Maybe i can make this work. Thought their might be a special cable for this.
Re: throttle cable for T ram [Re: mopar dave] #2800681
07/24/20 04:45 PM
07/24/20 04:45 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
115883929_3213631238695563_2844677423565816809_n.jpg115887541_3213631288695558_5539437439639970251_n.jpg
Re: throttle cable for T ram [Re: CSK] #2800683
07/24/20 04:49 PM
07/24/20 04:49 PM
Mt Morris Michigan
Mt Morris Michigan
Thank you.
Re: throttle cable for T ram [Re: mopar dave] #2800875
07/25/20 08:03 AM
07/25/20 08:03 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I prefer the Lokar cable.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: throttle cable for T ram [Re: hemi-itis] #2800879
07/25/20 08:19 AM
07/25/20 08:19 AM
Mt Morris Michigan
Mt Morris Michigan
I see. I think i can make this work with the cable i have. Thanks for the pic
Re: throttle cable for T ram [Re: hemi-itis] #2801061
07/25/20 04:11 PM
07/25/20 04:11 PM
Cab_Burge Online work
Cab_Burge  Online Work
Says the man who likes shiny and puddy tats haha
Re: throttle cable for T ram [Re: Cab_Burge] #2801229
07/26/20 08:49 AM
07/26/20 08:49 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I'd only use a bell crank if I was using a linkage rod from the pedal. Using a cable, the bell crank is redundant since the cable is flexible. Run your cable up to the carb directly like you would on a single 4. You get direct movement, and drop a bunch of other parts.
Use a morse cable, and a toe hook on the pedal. Then you can forcible close the throttle if need be.
Re: throttle cable for T ram [Re: Cab_Burge] #2801408
07/26/20 04:39 PM
07/26/20 04:39 PM
hemi-itis Offline
hemi-itis  Offline
Bling,purrrrrrrrrrrrr
Re: throttle cable for T ram [Re: hemi-itis] #2801539
07/26/20 10:21 PM
07/26/20 10:21 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Lokar throttle cable and A@R engineering throttle bracket
1.39 9.85 - 137 mph
