Re: R5p7 power [Re: NoFrills] #2798908
07/20/20 12:36 PM
07/20/20 12:36 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Originally Posted by NoFrills
I still have the nascar cam in it. Learned that basically the roller ones are all around .750 lift older ones have around a .440 lobe newer have a .350 ish with a much bigger rocker. Also learned have to watch out for what cam gear it has on the back there where some different ones. Engine guy was very knowledgeable with r5 and r6s has a few dozen of them around his shop he had worked for Arrington for years and was involved with alot of the development. He had told me there is probably 25 hp in a purpose built cam but its going to be ruff on the valve train. I figured they had spent more money developing this stuff then i will probably ever make in my life why try and reinvent it. Would be different if i did not have to drive it track to track.
So is it a flat tappet cam in it now?
If so, sounds extremely similar to one my buddy bought and stuck in a 3000 pound ( with him on it)69 Dart with a 904 behind it.
Ran 9.40’s at 143 best pass.
Ran it several years. Nice piece.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: R5p7 power [Re: B3422W5] #2799153
07/20/20 09:50 PM
07/20/20 09:50 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Sounds like it's a roller camshaft, based on the lift numbers he mentioned. I have been looking at roller cams and they all seem to be around the 0.430:-0.440" range the OP mentioned. But I could be wrong
Alan Jones
Re: R5p7 power [Re: LA360] #2799157
07/20/20 10:00 PM
07/20/20 10:00 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Dont remember the lift( maybe he will see this thread)
Know the motor was 12 to 1, was ran in a Busch restrictor plate deal, and the cam was 248/258 @ 50
Had a very well known head guy flow them and they went 400 ish. Very impressive heads
1.41 best 60 foot
6.60 at 103.90 1/8
Re: R5p7 power [Re: B3422W5] #2799163
07/20/20 10:19 PM
07/20/20 10:19 PM
LA360 Offline
LA360  Offline
If it was a Busch engine, it will be a roller camshaft engine. Only the Sprint Cup stuff is flat tappet, and from what I've seen, not a lot are sold off complete. Seems to be the Busch stuff mainly, with the odd Crasftman Truck engine. Dodge hasn't produced these engines since around 2007. I am surprized more people haven't jumped on the bandwagon
Alan Jones
Re: R5p7 power [Re: LA360] #2799270
07/21/20 09:21 AM
07/21/20 09:21 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
You are right. I asked him. Cam specs were right, but was a roller truck restrictor plate motor. He bought it complete and running
1.41 best 60 foot
6.60 at 103.90 1/8
Re: R5p7 power [Re: NoFrills] #2799426
07/21/20 03:08 PM
07/21/20 03:08 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Its getting a clutchless g force 5 speed 3.29 1st with a black magic clutch 4.30 gear plan on shifting 1-4 at the track and 5th for the street
What's this monster going into, so that I can avoid it if I happen to cross paths...
