Re: 67 9-1/4 rear?
[Re: DoctorDiff]
#2798228
07/18/20 10:40 AM
07/18/20 10:40 AM
Posts: 10,735 North Dakota
6PakBee
North Dakota
440 4-speed C-bodies came with a 9 1/4" Dana 53 rear. This is not the same as the newer 9.25" Chrysler corporate rearend. Wow, not too many of those puppies around.
Re: 67 9-1/4 rear?
[Re: cudaman1969]
#2798335
07/18/20 02:20 PM
07/18/20 02:20 PM
Posts: 21,448 It's a dry heat
gtx6970
It's a dry heat
Looking thru the 67 Plymouth service manual, looking in the section on the rear axels. It says the Hemi 4 speed uses the Dana -9-3/4 but the 440 4 speed used the -9-1/4 rear. I personally have never seen one and was under the assumption the Dana was used. Would this 9-1/4 be the same as the 70-80 truck rear? I did part out a 68 and 69 440 4 speed car and both had the 9-3/4 dana. Was it a one year only thing? Typo
Re: 67 9-1/4 rear?
[Re: mccannix]
#2798395
07/18/20 05:17 PM
07/18/20 05:17 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Factory Dana 53 that I removed from a 1967 Fury 440-4 speed Here is another one 3.31,perfect fit in a 62 B-body,no alterations what so ever.
Re: 67 9-1/4 rear?
[Re: gtx6970]
#2798646
07/19/20 04:45 PM
07/19/20 04:45 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Looking thru the 67 Plymouth service manual, looking in the section on the rear axels. It says the Hemi 4 speed uses the Dana -9-3/4 but the 440 4 speed used the -9-1/4 rear. I personally have never seen one and was under the assumption the Dana was used. Would this 9-1/4 be the same as the 70-80 truck rear? I did part out a 68 and 69 440 4 speed car and both had the 9-3/4 dana. Was it a one year only thing? Typo Not a typo, the Dana 53 has a 9 1/4" ring gear. From the '67 C-Body manual:
Re: 67 9-1/4 rear?
[Re: John_Kunkel]
#2798663
07/19/20 06:13 PM
07/19/20 06:13 PM
gtx6970
It's a dry heat
Looking thru the 67 Plymouth service manual, looking in the section on the rear axels. It says the Hemi 4 speed uses the Dana -9-3/4 but the 440 4 speed used the -9-1/4 rear. I personally have never seen one and was under the assumption the Dana was used. Would this 9-1/4 be the same as the 70-80 truck rear? I did part out a 68 and 69 440 4 speed car and both had the 9-3/4 dana. Was it a one year only thing? Typo Not a typo, the Dana 53 has a 9 1/4" ring gear. From the '67 C-Body manual: The original post was about the service manual stating of a 9-1/4 Dana in a B body. yet no such animal exists THATS a typo.
Re: 67 9-1/4 rear?
[Re: gtx6970]
#2798682
07/19/20 07:13 PM
07/19/20 07:13 PM
John_Kunkel
Rio Linda, CA
Read the OP again, no mention of what body in either the header or the text, only says "67 Plymouth service manual".
Re: 67 9-1/4 rear?
[Re: John_Kunkel]
#2798745
07/19/20 10:02 PM
07/19/20 10:02 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
I showed the book (all bodies) and the paragraph, said 440 4 speeds came with the 9-1/4 rear, Dana was EXCLUSIVELY (highlighted) for the Hemi 4 speed. So the book gave the wrong info, not enough info or was a typo. Made it sound like 440 b-bodies came with the 9-1/4 in 67 which I doubted but Chrysler did some crazy things. So I asked. Looking up I see we’re referencing two different books.
Re: 67 9-1/4 rear?
[Re: cudaman1969]
#2799168
07/20/20 10:29 PM
07/20/20 10:29 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Well it’s not exclusive if the 440 4 speed GTX (b-body) got the 9-3/4 also. It implies the 4speed Hemi is the only one that gets the Dana 60 which it clearly doesn’t. That's part of my point. Other models may have the Dana depending on the order system. Exclusive means that this is all that is available or what you are going to get on a car ordered with the Hemi and a 4 speed no matter what model..
Re: 67 9-1/4 rear?
[Re: gtx6970]
#2799177
07/20/20 10:49 PM
07/20/20 10:49 PM
62maxwgn
Blair County,PA
Looking thru the 67 Plymouth service manual, looking in the section on the rear axels. It says the Hemi 4 speed uses the Dana -9-3/4 but the 440 4 speed used the -9-1/4 rear. I personally have never seen one and was under the assumption the Dana was used. Would this 9-1/4 be the same as the 70-80 truck rear? I did part out a 68 and 69 440 4 speed car and both had the 9-3/4 dana. Was it a one year only thing? Typo Not a typo, the Dana 53 has a 9 1/4" ring gear. From the '67 C-Body manual: The original post was about the service manual stating of a 9-1/4 Dana in a B body. yet no such animal exists THATS a typo. Bill,how then did I end up with the one that went in my 62 with absolutely no modifications ?
