Dash Vacuum Switch /// What Is This??? #2796771
07/14/20 11:55 PM
07/14/20 11:55 PM
West Central Wisconsin
DeMopuar Offline OP
DeMopuar  Offline OP
Just curious if anyone knows the correct application for the part I have posted photos of here? You can see there is a vacuum switch of some kind as well as an electrical contact on the same switch. Very cool piece - but the box was lost long ago and there's no part number that I can see on this anywhere.
Re: Dash Vacuum Switch /// What Is This??? [Re: DeMopuar] #2796811
07/15/20 06:41 AM
07/15/20 06:41 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
I think headlight washers are vacuum controled? And the electrical section for the water pump/squirters. I guess C body/Imperials ? 71 Chargers with that option go at a different switch down the dash.
Re: Dash Vacuum Switch /// What Is This??? [Re: NachoRT74] #2797141
07/15/20 06:55 PM
07/15/20 06:55 PM
DeMopuar Offline OP
DeMopuar  Offline OP
Makes sense - thanks for the information!!!!!!!
Re: Dash Vacuum Switch /// What Is This??? [Re: NachoRT74] #2797242
07/16/20 03:32 AM
07/16/20 03:32 AM
Valencia, España
Valencia, España
Well actually was my first thought, but I can't tell it for sure!
Re: Dash Vacuum Switch /// What Is This??? [Re: NachoRT74] #2797539
07/16/20 06:33 PM
07/16/20 06:33 PM
Castlegar, BC, Canada
That AMC Guy Offline
Might depend on the model year. Friend of mine has/had a fully loaded '69 Imperial coupe, and the headlight washers are activated when the headlights are on, windshield wipers are on and you press the button to squirt the windshield. There is no separate control for them.
Could this be a switch for a rear de-fogger / defroster?
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Dash Vacuum Switch /// What Is This??? [Re: That AMC Guy] #2797700
07/17/20 02:19 AM
07/17/20 02:19 AM
Valencia, España
Valencia, España
Databook says needs to press button to work. Sure headlights need to be on, but is not working allways headlights are on.
