How much hp can a 2004 mopar mega block handle. #2797357
07/16/20 11:36 AM
07/16/20 11:36 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I just bought a iron mega block. Says 2004 date code.
Was going to be a 498ci.
How much can you throw at these BBs?
1st time with a BB.
Wanted a hemi but couldnt pass up this deal.
Re: How much hp can a 2004 mopar mega block handle. [Re: Sammy] #2797365
07/16/20 11:57 AM
07/16/20 11:57 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I don't know but I just finished a 2001 block that makes 1060 hp and I have zero concerns.
Re: How much hp can a 2004 mopar mega block handle. [Re: Sammy] #2797387
07/16/20 12:41 PM
07/16/20 12:41 PM
gregsdart Offline
gregsdart  Offline
I wouldn't worry. I make 860 to 880 hp and spin mine to 7500 rpm no serious problems in 17 years.
Re: How much hp can a 2004 mopar mega block handle. [Re: Sammy] #2797414
07/16/20 01:17 PM
07/16/20 01:17 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
How do you tell the date? Just picked up a Hemi block and haven’t seen a date
Re: How much hp can a 2004 mopar mega block handle. [Re: cudaman1969] #2797440
07/16/20 02:06 PM
07/16/20 02:06 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I am looking to go Supercharger.
I'm not getting any younger so before I can't race anymore, I figure I'll spend the kids inheritence.
Looming for 2400 hp.
Re: How much hp can a 2004 mopar mega block handle. [Re: Sammy] #2797444
07/16/20 02:15 PM
07/16/20 02:15 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
So you do need to ask!
Re: How much hp can a 2004 mopar mega block handle. [Re: cudaman1969] #2797445
07/16/20 02:16 PM
07/16/20 02:16 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I don't know - I bought mine new in 2001 so I know it was 2001 vintage.
Re: How much hp can a 2004 mopar mega block handle. [Re: markz528] #2797448
07/16/20 02:32 PM
07/16/20 02:32 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Pre-World are usually very difficult to tell the manufacturing date.
Even with the later World style, all we ever got was a machining date....Dalton wasn't required to stamp the blocks or
anything like that, so the casting date is a Mopar Mystery.
Rich H.
Esse Quam Videri
Re: How much hp can a 2004 mopar mega block handle. [Re: ZIPPY] #2797456
07/16/20 02:48 PM
07/16/20 02:48 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Supercharged and 2400hp?
You should be looking for a better block IMO.
Re: How much hp can a 2004 mopar mega block handle. [Re: Sammy] #2797462
07/16/20 02:58 PM
07/16/20 02:58 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I would think it would handle that.
2011 Drag Pak Challenger
Re: How much hp can a 2004 mopar mega block handle. [Re: fast68plymouth] #2797480
07/16/20 03:24 PM
07/16/20 03:24 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Like what?
I'm not too happy with the added weight up front but I was told that the cylinders don't move around like a aluminum block.
Re: How much hp can a 2004 mopar mega block handle. [Re: rickseeman] #2797481
07/16/20 03:26 PM
07/16/20 03:26 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
These are uncharted waters for me. Not sure what a good mopar performance mega block can handle.
Re: How much hp can a 2004 mopar mega block handle. [Re: cudaman1969] #2797487
07/16/20 03:43 PM
07/16/20 03:43 PM
central il.
second 70 Offline
second 70  Offline
central il.
I don't know for sure but my mega hemi block has 11 94 on top pad and 6K29 on side. So it could be Nov. 94 or might be a 1-19-2004 or neither. lol
Re: How much hp can a 2004 mopar mega block handle. [Re: Sammy] #2797492
07/16/20 03:53 PM
07/16/20 03:53 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Have a nice day
Boffin Emeritus
Re: How much hp can a 2004 mopar mega block handle. [Re: polyspheric] #2797510
07/16/20 04:42 PM
07/16/20 04:42 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Those top fuel aluminum blocks handle 10,000 hp are they any good?
Re: How much hp can a 2004 mopar mega block handle. [Re: polyspheric] #2797511
07/16/20 04:43 PM
07/16/20 04:43 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by polyspheric
Can't answer the question, but as I understand it the survival of a block depends in part on how the power is made.
Supposedly nitrous is the worst, followed by normally aspirated (high static CR, high RPM), then boosted.
I've heard (but not agree at this point) that twin screw (Whipple, Autorotor) is the roughest of the boost group, turbo the softest, but no actual results.
2400 sounds dangerous, but then I'm old.
At that power level I can't see aluminum as safe weight saving is erased by worries about water leaks, ring seal, inconsistent oil pressure, distortion. Those serious-but-budget LSX engines use factory iron blocks. My 183" Toyota L6 iron block is supposed to be safe at 1,500.
Why is nitrous "the worst"?
'63 Dodge 330
11.19 @ 121 mph
Re: How much hp can a 2004 mopar mega block handle. [Re: cudaman1969] #2797514
07/16/20 04:50 PM
07/16/20 04:50 PM
an8sec70cuda Offline
iagreeLook at all the big HP hemis running pro mod and every other class...all aluminum blocks.
The chevy LS guys are using aluminum blocks more and more too. One of the fastest stock block LS cars in the country is an aluminum 5.3 based build. I helped a friend with one he took to Lights Out at SGMP.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How much hp can a 2004 mopar mega block handle. [Re: Sammy] #2797517
07/16/20 05:16 PM
07/16/20 05:16 PM
These are uncharted waters for me. Not sure what a good mopar performance mega block can handle. [/quote]
I don't think I would want to be the test mule and do R&D for your deal down tsk 2400 HP sounds like it is directly in the danger zone for standard cast grey iron
I have a new Koleno high nickel block that I want to use to build a N/A Top Sportsman motor that will make north of 1000 HP with a set of B1-MC and dual dominators on a tunnel ram, I'm thinking it is good to 1800+HP.
I have a new KB aluminum wedge block on order , Tim at FHO tells me it is good to 4000+HP work
Re: How much hp can a 2004 mopar mega block handle. [Re: Sammy] #2797522
07/16/20 05:29 PM
07/16/20 05:29 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: How much hp can a 2004 mopar mega block handle. [Re: Sammy] #2797523
07/16/20 05:33 PM
07/16/20 05:33 PM
gregsdart Offline
gregsdart  Offline
Like what?
See if you can get in contact with some top alcohol engine builders. They will know what will work and more importantly for how long.
