Re: Big Block Heater
[Re: 69dart]
#2796177
07/13/20 02:23 PM
07/13/20 02:23 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
After switching to alky this year it was recommended to install a freeze plug style block heater to keep the engine warm between rounds.
Does anyone know a part number for a simple freeze plug block heater I can install?
Not interested in debating the block heater just looking for help locating the best part for it.
Thank You!!! I agree a block heater would be good, BUT a freeze plug type on a race car I would be worried it would blow out. look at a oil heater maybe , Google,,, some that go in the lower hose
[Re: 69dart]
#2796199
07/13/20 03:19 PM
07/13/20 03:19 PM
Posts: 630 Ct
Wirenut
Ct
Thank You!!! My first aky car had a in line heater in the lower hose. Never needed to use it even running in 50* weather. Just FYI I found putting a padded moving blanket over the engine after hot works well , and I assume you have a lean out Valve.
[Re: Wirenut]
#2796243
07/13/20 05:03 PM
07/13/20 05:03 PM
Posts: 1,030 ohio
67mprfan
ohio
Not sure if you are using a dipstick but would that be a option
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: tboomer]
#2796268
07/13/20 05:56 PM
07/13/20 05:56 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My son bought his soft plug style block heaters from Jegs. Zero issues with them.
