Big Block Heater #2796150
07/13/20 01:06 PM
07/13/20 01:06 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
After switching to alky this year it was recommended to install a freeze plug style block heater to keep the engine warm between rounds.
Does anyone know a part number for a simple freeze plug block heater I can install?
Not interested in debating the block heater just looking for help locating the best part for it.
Thank You!!!
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Big Block Heater [Re: 69dart] #2796177
07/13/20 02:23 PM
07/13/20 02:23 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thank You!!!
I agree a block heater would be good, BUT a freeze plug type on a race car I would be worried it would blow out. look at a oil heater maybe , Google,,, some that go in the lower hose
Re: Big Block Heater [Re: 69dart] #2796191
07/13/20 02:53 PM
07/13/20 02:53 PM
AndyF Online content
AndyF  Online Content
I used to buy them from the local Dodge dealer. Not sure if they are still available or not but might be. Very common part. I probably still have a couple sitting in a box on my shelf.
Re: Big Block Heater [Re: 69dart] #2796199
07/13/20 03:19 PM
07/13/20 03:19 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Thank You!!!
My first aky car had a in line heater in the lower hose. Never needed to use it even running in 50* weather. Just FYI I found putting a padded moving blanket over the engine after hot works well , and I assume you have a lean out Valve.
Re: Big Block Heater [Re: Wirenut] #2796243
07/13/20 05:03 PM
07/13/20 05:03 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Not sure if you are using a dipstick but would that be a option
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Big Block Heater [Re: 67mprfan] #2796259
07/13/20 05:45 PM
07/13/20 05:45 PM
tboomer Online work
tboomer  Online Work
How about an oil pan heater that you can buy at a farm store? shruggy
Re: Big Block Heater [Re: tboomer] #2796268
07/13/20 05:56 PM
07/13/20 05:56 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
My son bought his soft plug style block heaters from Jegs. Zero issues with them.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Big Block Heater [Re: pittsburghracer] #2796508
07/14/20 01:06 PM
07/14/20 01:06 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
Yeah - all the chevy guys I congregate with run them. They barely even warm up the cars - they just head to the lanes. Several track championships can't be wrong.
I have a lean out but it would be nice to pull up to the trailer door, plug it in and know its always ready for the next round, especially come fall. These tiny things are often the .000 differences between winning and losing.
68 Dart - 340
66 Belvedere - 400
