Using shaft and pushrod oiling #2794519
07/08/20 09:49 PM
07/08/20 09:49 PM
AB
P
Pockets Offline OP
Pockets  Offline OP
P
AB
Planning a 526 stroker build using an Indy aluminum block. 440-1 345 heads, solid roller. Am looking at having Harland Sharp make some 1.7 rockers, which they will for the same price as 1.5/1.6. But also wondering about keeping the shaft oiling and running pushrod oiling as well. I was planning on using the AMC Comp lifter 861, then pushrods with a .040" restriction. Also using a cup adjuster and ball/ball pushrods. Is that all I need to do? The adjuster doesn't need to have an oil hole does it? I just want more oil to the pushrod ends/adjuster cup.
Re: Using shaft and pushrod oiling [Re: Pockets] #2794526
07/08/20 10:40 PM
07/08/20 10:40 PM
My current 518 C.I. S/P bracket motor had both pushrod oiling and spray bar oiling for the Jesel paired shaft rockers on the 440-1 heads, I ran it that way for a while and ended up removing the spray bar covers after having a lot more oil get into the vacuum pump with the other motor in it for five years with full time oiling to the Harland Sharp single shaft rockers restricted to .040 to each rocker shaft.
The Jesel paired shaft rockers oil straight through the adjusters with no oiling provisions to the shafts or roller tips, Jesel tech. said it will oil fine with splash oiling only to those parts shruggy It has so far shifting at 7300 RPM and crossing the finish line in the 1/4 mile over 7500 RPM shruggy work Ask Harland Sharp to use pushrod oiling adjusters in your set scope twocents If they won't you can buy them direct from Manton, I'm a Manton dealer also whistling up
Try it first and see how you like it and then decide to keep it both ways or not twocents
Re: Using shaft and pushrod oiling [Re: Pockets] #2794527
07/08/20 10:40 PM
07/08/20 10:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No you wont need the rockers set up.. just the push rods .. your lash will get the oil onto the rocker rollers
and your running standard oiling also so you should be set
wave
Re: Using shaft and pushrod oiling [Re: MR_P_BODY] #2794596
07/09/20 06:25 AM
07/09/20 06:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
.040" is as big as I would go. Many Indy heads oil through a single .040" orifice. My Indy -1 motor push rod oil's. With 16 .040" orifices and spray bars you may want to look at a high volume pump. Though my push rods are .055" if I did it over they would be smaller.
Doug
Re: Using shaft and pushrod oiling [Re: dvw] #2794841
07/09/20 05:05 PM
07/09/20 05:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The 861 lifters have edge orifice oiling and the correct clocking of the oil feed hole....... so no restrictions to the top end in the pushrods are needed.
Re: Using shaft and pushrod oiling [Re: fast68plymouth] #2796011
07/12/20 11:20 PM
07/12/20 11:20 PM
AB
P
Pockets Offline OP
Pockets  Offline OP
P
AB
Thanks for the replies.
I am also going to use cup style adjusters and ball/ball pushrods. Do I need adjusters with thru oiling?
Re: Using shaft and pushrod oiling [Re: Pockets] #2796017
07/12/20 11:55 PM
07/12/20 11:55 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I am running both oiling, I do have the oil through adjuster T&D rockers Ball Ball push rods 5k miles street & strip.
Re: Using shaft and pushrod oiling [Re: CSK] #2927650
05/28/21 12:56 PM
05/28/21 12:56 PM
AB
P
Pockets Offline OP
Pockets  Offline OP
P
AB
So this build is nearing completion, and the person assembling the top end has some concerns.
It is an Indy Maxx aluminum block, lifter bores are not bushed, they are aluminum. With the 861-16 lifters he thinks that the lifters cannot receive oil to feed the pushrods with just the lifter to lifter bore clearance. He thinks that the lifter bores needs to be drilled to feed the lifter. I said that they don't.
It was planned to use cup style adjusters and ball/ball pushrods, but he insists that will not work, that we need ball adjuster and cup/ball pushrods, as the pushrod oiling will not work without a pressurized oil feed hole in the lifter bore to feed the lifter.
Is there something I am overlooking in this?
Re: Using shaft and pushrod oiling [Re: Pockets] #2927660
05/28/21 01:27 PM
05/28/21 01:27 PM
So. Burlington, Vt.
So. Burlington, Vt.
I assume you had the option for lifter oiling done to the block.
If the way the lifter bores are oiled is similar to stock, no mods to oil the top end is necessary when using the 861 lifters.
Unless other modifications have been done to the HS rockers to facilitate the oil getting from the pushrod into the rocker arm, the only thing you’re accomplishing with oil going up the pushrod is improving the lubrication to the adjuster.
Re: Using shaft and pushrod oiling [Re: fast68plymouth] #2927664
05/28/21 01:36 PM
05/28/21 01:36 PM
AB
P
Pockets Offline OP
Pockets  Offline OP
P
AB
I do not know what was done to the block, my friend bought it 2nd hand, it had been prepped to use, but never was. Is the Indy block the same as factory for oiling the lifter area?
All we are looking to do is have the pushrod tip oiled, in addition to the standard rocker shaft oiling.
Re: Using shaft and pushrod oiling [Re: Pockets] #2927698
05/28/21 02:24 PM
05/28/21 02:24 PM
NC
440Jim Offline
440Jim  Offline
NC
The way I understand it, You have to order the Indy block for pushrod oiling (cost additional). Otherwise the lifters don't have an oil gallery, just splash oiling.
Re: Using shaft and pushrod oiling [Re: 440Jim] #2927722
05/28/21 03:06 PM
05/28/21 03:06 PM
So. Burlington, Vt.
So. Burlington, Vt.
Correct.
Re: Using shaft and pushrod oiling [Re: fast68plymouth] #2927728
05/28/21 03:18 PM
05/28/21 03:18 PM
AB
P
Pockets Offline OP
Pockets  Offline OP
P
AB
Ok, so if that were the case, no oil gallery, would the hi pressure pin oiling of the 861 lifter not receive oil either?
Re: Using shaft and pushrod oiling [Re: Pockets] #2927734
05/28/21 03:27 PM
05/28/21 03:27 PM
AndyF Offline
AndyF  Offline
Correct. No pressure means no pressure. The 861 lifters will just have splash oiling if the gallery isn't drilled so no pressure for the pin and no pressure for the pushrod.
Re: Using shaft and pushrod oiling [Re: AndyF] #2927745
05/28/21 03:37 PM
05/28/21 03:37 PM
So. Burlington, Vt.
So. Burlington, Vt.
It will only require a visual inspection.
The lifter bores either have oil feed holes........ or they don’t.
I’ve only used one Indy block, and it didn’t get the lifter bore oiling mod.
No oil holes in the lifter bores.
Re: Using shaft and pushrod oiling [Re: fast68plymouth] #2927799
05/28/21 05:42 PM
05/28/21 05:42 PM
AB
P
Pockets Offline OP
Pockets  Offline OP
P
AB
Ok, thanks for the answers. Can this mod be done to the block as it is with the unbushed lifter bores, or do the bores need to be bushed and the oiling mod done? And can this even be done to the block if it wasn't ordered with it?
Re: Using shaft and pushrod oiling [Re: Pockets] #2927808
05/28/21 05:57 PM
05/28/21 05:57 PM
AndyF Offline
AndyF  Offline
You would need to talk to someone like Best Machine. It takes some special equipment to drill a straight hole that long thru a block. Not a DIY type of project.
