Re: Gas tank difference 73-74 Satellite Charger
[Re: RUMBLON]
#2794396
07/08/20 03:44 PM
07/08/20 03:44 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
74 has the vapor recovery tank in the fuel tank thus the large hump up on top. 73 has a small external vapor tank up on the shock cross member. You can use the 73 tank and get the small external vapor tank or do away with all together.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparx]
#2794724
07/09/20 01:50 PM
07/09/20 01:50 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
when I got my 74 Gas tank can't recall if lock ring was included ( 12 years of that ) , but I can say the problem with them is not the lock ring, but the welded ring to the tank which locks the lock ring. It bends as soon you tight up the lock ring. So needs to be made carefully.
[Re: NachoRT74]
#2794742
07/09/20 02:22 PM
07/09/20 02:22 PM
Posts: 19,355 north of coder
moparx
i remember the problem, but i didn't remember if it was the lock ring, or the retainer on the tank. i have a new stainless tank that came with a stainless lock ring, but i haven't installed it yet. i will have to compare both the ring and the retainer on the new tank to the old one, and watch closely for anything starting to bend or leak when i install the new sending unit, which is also stainless.
[Re: moparx]
#2794789
07/09/20 03:37 PM
07/09/20 03:37 PM
Posts: 3,378 KY USA
mopargem
KY USA
i remember the problem, but i didn't remember if it was the lock ring, or the retainer on the tank. i have a new stainless tank that came with a stainless lock ring, but i haven't installed it yet. i will have to compare both the ring and the retainer on the new tank to the old one, and watch closely for anything starting to bend or leak when i install the new sending unit, which is also stainless. Ive never had the new rings fit well with any of the new tanks Ive gotten over the years so I always reuse the old lock ring
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#2795080
07/10/20 09:47 AM
07/10/20 09:47 AM
NachoRT74
Valencia, España
I also reused the old lock ring but mostly because I preffer to keep Factory parts on my car as far they are useable than repros. I couln't notice a diff on size and shape between the repro lock ring and the original, but I didn't even tried. The problem for me was the reatiner ring welded on tank.
Maybe if I was to use the new one I was to find both would bend? LOL.
I didn't get any problem with leakage thought. In fact I had to remove the lock ring, get straightened back the retainer ring on tank, and install the lock ring back gently.
