Gas tank difference 73-74 Satellite Charger #2794366
07/08/20 02:36 PM
07/08/20 02:36 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I have a question. I have a 74 satellite and need a fuel tank. In rock auto the fuel tanks are different between the 73 and 74 years and $100 more expensive in 74.
The cars are basically the same so I’m wondering why the difference? Emissions?
The parts numbers are the same for 73 chargers and satellite as well
Then in 74 there is a large hump on top of the 74 for both ?
I talked to a guy who’s using a 73 tank in his 74 but I’m curious on what’s different ? Any ideas
Re: Gas tank difference 73-74 Satellite Charger [Re: RUMBLON] #2794396
07/08/20 03:44 PM
07/08/20 03:44 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
74 has the vapor recovery tank in the fuel tank thus the large hump up on top. 73 has a small external vapor tank up on the shock cross member.
You can use the 73 tank and get the small external vapor tank or do away with all together.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Gas tank difference 73-74 Satellite Charger [Re: moparmarks] #2794424
07/08/20 05:21 PM
07/08/20 05:21 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Thx. Kinda what I thought. Think I will save the money and ditch the system. Thx again
Re: Gas tank difference 73-74 Satellite Charger [Re: RUMBLON] #2794718
07/09/20 01:39 PM
07/09/20 01:39 PM
moparx Offline
moparx  Offline
i noticed the tank description stated a lock ring kit was included.
has anyone took note if the lock ring was thinner than the factory part, or if the lock ring was correctly sized to the new tank ?
beer
Re: Gas tank difference 73-74 Satellite Charger [Re: moparx] #2794724
07/09/20 01:50 PM
07/09/20 01:50 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
when I got my 74 Gas tank can't recall if lock ring was included ( 12 years of that ) , but I can say the problem with them is not the lock ring, but the welded ring to the tank which locks the lock ring. It bends as soon you tight up the lock ring. So needs to be made carefully.
Re: Gas tank difference 73-74 Satellite Charger [Re: NachoRT74] #2794742
07/09/20 02:22 PM
07/09/20 02:22 PM
moparx Offline
moparx  Offline
i remember the problem, but i didn't remember if it was the lock ring, or the retainer on the tank.
i have a new stainless tank that came with a stainless lock ring, but i haven't installed it yet.
i will have to compare both the ring and the retainer on the new tank to the old one, and watch closely for anything starting to bend or leak when i install the new sending unit, which is also stainless.
beer
Re: Gas tank difference 73-74 Satellite Charger [Re: moparx] #2794789
07/09/20 03:37 PM
07/09/20 03:37 PM
KY USA
mopargem Online tonguue
mopargem  Online Tonguue
KY USA
beer
Ive never had the new rings fit well with any of the new tanks Ive gotten over the years so I always reuse the old lock ring
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Gas tank difference 73-74 Satellite Charger [Re: mopargem] #2795080
07/10/20 09:47 AM
07/10/20 09:47 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I also reused the old lock ring but mostly because I preffer to keep Factory parts on my car as far they are useable than repros. I couln't notice a diff on size and shape between the repro lock ring and the original, but I didn't even tried. The problem for me was the reatiner ring welded on tank.
Maybe if I was to use the new one I was to find both would bend? LOL.
I didn't get any problem with leakage thought. In fact I had to remove the lock ring, get straightened back the retainer ring on tank, and install the lock ring back gently.
