Re: Throttle enhancers
[Re: burdar]
#2794206
07/08/20 09:19 AM
07/08/20 09:19 AM
Posts: 4,922 new berlin wisconsin
Mr T2U
i don't know anything about rams with hemi's and the delay on acceleration after stepping on the pedal.. i own a tuned 08 mustang and this is a somewhat common complaint on mustangs. especially ones that have cheap, universal canned, tunes done to them. it's easily corrected thru a proper tune.
perception is 90% of reality
[Re: Moparmick]
#2794213
07/08/20 09:40 AM
07/08/20 09:40 AM
Posts: 1,407 Central Pa
moparjim79
Central Pa
Anybody have any info on which is best or worst for 2011 ram hemi One of my friends has one on his '12. I think it's called a throttle command? Said it was the best $200 hes spent on a vehicle, totally changed the driving experience. Several settings and you can customize settings as well.
[Re: Moparmick]
#2794672
07/09/20 11:52 AM
07/09/20 11:52 AM
Posts: 9,836 MI, usa
dvw
MI, usa
The stock drive by wire has a pretty good delay. My son drag races a 2017 Scat Pac. The reaction times are way slow unless you sneak it in the beams or guess. He can normally go .020 or better in hi normal car. This car is closer to .100 Doug
