Removing Pulley from Alternator #2793572
07/06/20 06:22 PM
07/06/20 06:22 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
After changing the bad alternator on my 96 Ram Pick Up a few years back with correct replacement, I threw a belt because now I realize the pulley that is on it is too small.
As when I put the new belt on last week, I can see it riding on the lip. It is up against the back of the pulley all the way, it just ran out of room .
Using a gates K070976 belt as was the last one. I rechecked compatibility and it is correct.
I can get a cheap enough pulley with the correct amount of grooves, but how do I get the pulley off the alternator?
Anyone do this? How difficult is it?
Thanks for the replies.
And if anyone has the right size pulley feel free to PM me wink
Mopar
Or
No
Car
Re: Removing Pulley from Alternator [Re: MONC] #2793626
07/06/20 08:02 PM
07/06/20 08:02 PM
AndyF Offline
AndyF  Offline
You probably need an alternator pulley pulling tool.
Re: Removing Pulley from Alternator [Re: MONC] #2793660
07/06/20 09:05 PM
07/06/20 09:05 PM
A727Tflite Offline
A727Tflite  Offline
Post a picture of how the belt is riding on that pulley.
Re: Removing Pulley from Alternator [Re: A727Tflite] #2793807
07/07/20 09:13 AM
07/07/20 09:13 AM
MONC Offline OP
MONC  Offline OP
It'll ride up no matter what
Mopar
Or
No
Car
Re: Removing Pulley from Alternator [Re: MONC] #2793809
07/07/20 09:19 AM
07/07/20 09:19 AM
A727Tflite Offline
A727Tflite  Offline
If nothing has been touched and this is a recent situation check out the tensioner first, the pivot can cause very slight misalignment and will cause this.
Any idler can cause this too.
Re: Removing Pulley from Alternator [Re: A727Tflite] #2793923
07/07/20 02:57 PM
07/07/20 02:57 PM
MONC Offline OP
MONC  Offline OP
Thanks I'll take a closer look.
I think it's been like this since I changed alternator 2 years ago.
Unfortunately can't go back to them now, as pulley looks smaller than what is supposed to be on there from what I can find.
Not sure how easy it is going to be to remove pulley .
Will I be able to do it still installed ?
Mopar
Or
No
Car
Re: Removing Pulley from Alternator [Re: MONC] #2793925
07/07/20 03:01 PM
07/07/20 03:01 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Looks like there is a nut holding the pulley on. Put an impact on it and it should buzz right off.
Re: Removing Pulley from Alternator [Re: burdar] #2793962
07/07/20 03:59 PM
07/07/20 03:59 PM
A727Tflite Offline
A727Tflite  Offline
If the tensioner is working thru it’s arc of adjustability it was designed for then the size of the pulley means nothing. The belt is riding off due to misalignment.
Something is driving it forward.
If this started after replacing the alternator then likely you have the alternator skewed.
Re: Removing Pulley from Alternator [Re: burdar] #2793974
07/07/20 04:13 PM
07/07/20 04:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, newer alternator pulleys aren't press-fit.
Re: Removing Pulley from Alternator [Re: John_Kunkel] #2793998
07/07/20 05:54 PM
07/07/20 05:54 PM
MONC Offline OP
MONC  Offline OP
I will check if alternator is skewed, but I don't believe it is.
I will see if the existing pulley will come off , thanks.
Mopar
Or
No
Car
