Educate me on Blowers.... #2793058
07/05/20 05:37 PM
07/05/20 05:37 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Thinking of still building a stroked 383 blower engine......Whats the latest available roots or screw blower tech? What are BDS Air Lock rotors? Do they make a roots blower that keeps up with a screw blower that does not need re-stripping?
Are any of them better than a Procharger?
Where is Hemi-itis when you need him?
Re: Educate me on Blowers.... [Re: Dragula] #2793103
07/05/20 07:26 PM
07/05/20 07:26 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
My roots 8-71 has 3 strips per lobe to seal any gap[.009] to the case.Depending on what hp you want to make.the small auto rotor or Lysholm[sp] can make some power.The roots is simple but the centrifugal need a fuel system built with it and is more money.I stuck with the basics.
Re: Educate me on Blowers.... [Re: Dragula] #2793125
07/05/20 08:13 PM
07/05/20 08:13 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I wouldn’t run a stripped blower on anything under 15 psi. Especially on a street car. Get the engine to flow better, big cam good heads, and a clearanced roots.
If you are racing and high boost, then start looking at stripped blowers. If you have buko mulah, get a psi blower!
Re: Educate me on Blowers.... [Re: Dragula] #2793128
07/05/20 08:25 PM
07/05/20 08:25 PM
Cab_Burge Online work
Cab_Burge  Online Work
Stay away from BDS, Bad Dam Service down for any roots blowers, call Littlefield at 714-992-9292 or some one else that makes decent products, not BDS twocents
Re: Educate me on Blowers.... [Re: Cab_Burge] #2793162
07/05/20 10:02 PM
07/05/20 10:02 PM
Superfreak
Superfreak
If you have money then go with a Whipple.
Re: Educate me on Blowers.... [Re: ] #2793256
07/06/20 07:57 AM
07/06/20 07:57 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
One of the best buys in roots now is a blower shop XR1. Extremely efficient, and about half the cost of a dmpe, bme or fowler. They'll set it up for whatever your use, or desired service interval is. They are the best I've seen in even distribution when only fed from the top too.
Re: Educate me on Blowers.... [Re: dthemi] #2793258
07/06/20 08:05 AM
07/06/20 08:05 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Bought the BDS over 20 years ago.Stage 3 with teflon strips and hardened case. I'm not up on the latest and greatest but the Blower Shop billet HH seems to be a good one. Is this a "race" only deal?
I am intercooling with nitrous,but corn works to an extent.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Educate me on Blowers.... [Re: Dragula] #2793302
07/06/20 09:54 AM
07/06/20 09:54 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Easy test for Roots development: is the discharge port a rectangle the full length of the rotors? Or a much smaller triangle directly behind the nose, with much of the rotor area masked?
Boffin Emeritus
Re: Educate me on Blowers.... [Re: polyspheric] #2793649
07/06/20 08:29 PM
07/06/20 08:29 PM
Dragula Offline OP
Dragula  Offline OP
Well that XR1 looks like a beast....Looks like all the good roots blowers are all nylon stripped. While it looks like the screw blowers are not.....I like the idea of no maintenance to the rotors just for consistency...When I was down at Jan Cen years ago, I got to watch Mike Jr re-strip a couple of rotors and make the nylon end caps.....All hand made tools and bench....WAPITA that looked like. couple that with 18 strips to an XR1 blower, and that seems expensive. I am also learning, none of these are cheap blowers....Just wondering if there is something better than a Procharger...Roots just look way better.
Re: Educate me on Blowers.... [Re: Dragula] #2793662
07/06/20 09:17 PM
07/06/20 09:17 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
SSI is close to me and I had my blower freshened there[400$]new bearings,strips...and I got to hange there all day and see there blower dyno at work with some top fuel blowers and see them make some billet rotors,cases.Very nise and smart people.
Re: Educate me on Blowers.... [Re: Clanton] #2793833
07/07/20 10:03 AM
07/07/20 10:03 AM
hemi-itis Offline
hemi-itis  Offline
I'm an exhibitionist, not a competitor.Once the teflon wears and clearanced it no longer wears.If your looking to squeeze every bit out of it they restripe those rotors every 2 or 3 runs.
Re: Educate me on Blowers.... [Re: Dragula] #2794201
07/08/20 09:06 AM
07/08/20 09:06 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I would like to hear more on the engine build and hp you want to make and use please. Magnuson ,Eaton are some other blowers maybe in the 4 liter range would work.
Re: Educate me on Blowers.... [Re: Clanton] #2794536
07/08/20 11:28 PM
07/08/20 11:28 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Hampton blowers don't use strips. GP hydroplanes run them for years and unless something goes through them, they require zero maintenance.
Kevin
