Re: Educate me on Blowers....
[Re: Dragula]
#2793103
07/05/20 07:26 PM
07/05/20 07:26 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Thinking of still building a stroked 383 blower engine......Whats the latest available roots or screw blower tech? What are BDS Air Lock rotors? Do they make a roots blower that keeps up with a screw blower that does not need re-stripping?
Are any of them better than a Procharger?
Where is Hemi-itis when you need him? My roots 8-71 has 3 strips per lobe to seal any gap[.009] to the case.Depending on what hp you want to make.the small auto rotor or Lysholm[sp] can make some power.The roots is simple but the centrifugal need a fuel system built with it and is more money.I stuck with the basics.
[Re: Dragula]
#2793125
07/05/20 08:13 PM
07/05/20 08:13 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I wouldn’t run a stripped blower on anything under 15 psi. Especially on a street car. Get the engine to flow better, big cam good heads, and a clearanced roots. If you are racing and high boost, then start looking at stripped blowers. If you have buko mulah, get a psi blower!
[Re: Cab_Burge]
#2793162
07/05/20 10:02 PM
07/05/20 10:02 PM
Superfreak
Superfreak
If you have money then go with a Whipple.
[Re: dthemi]
#2793258
07/06/20 08:05 AM
07/06/20 08:05 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Bought the BDS over 20 years ago.Stage 3 with teflon strips and hardened case. I'm not up on the latest and greatest but the Blower Shop billet HH seems to be a good one. Is this a "race" only deal? I am intercooling with nitrous,but corn works to an extent.
[Re: Dragula]
#2793302
07/06/20 09:54 AM
07/06/20 09:54 AM
Posts: 4,205 New York
polyspheric
New York
Easy test for Roots development: is the discharge port a rectangle the full length of the rotors? Or a much smaller triangle directly behind the nose, with much of the rotor area masked?
Boffin Emeritus
[Re: Clanton]
#2793833
07/07/20 10:03 AM
07/07/20 10:03 AM
hemi-itis
I'm an exhibitionist, not a competitor.Once the teflon wears and clearanced it no longer wears.If your looking to squeeze every bit out of it they restripe those rotors every 2 or 3 runs.
