clutch flite
#2792806
07/04/20 11:44 PM
07/04/20 11:44 PM
Posts: 5,106 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Any one ever run one of these in a healthy drag car. Since the class we are going to race in has changed the rules that you must use a clutch pedal was thinking using or changing out the auto and running all the good stuff in a clutch flite. Wondered what is the weak point in this set up and if there are any aftermarket billet stuff to correct the weak points. Motor likely will be a 605 Hemi around 1200 HP 3200 lbs E Body with a ladder bar.
1971 HEMI E BODY REGISTRY
Re: clutch flite
[Re: hemicar1971]
#2792808
07/05/20 12:03 AM
07/05/20 12:03 AM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My buddy blew one apart in his high 8 second front engine dragster. Hit a guy in the stands and the trans blanket looked like ground up fiberglass. Pretty sure Norwalk got sued over it.
Re: clutch flite
[Re: hemicar1971]
#2792851
07/05/20 07:45 AM
07/05/20 07:45 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The problem is getting parts. Unless you have the ability to make them, or are able to find parts in useable condition, you are going to have a tough time. Im building one for my early hemi. Doing something odd though... using an overdrive version, so the parts up front are not really available. I also plan on using a transbrake valvebody for holding the car in the beams. (Clutch pedal release switch) Im making 3 input shafts out of 300m. The cost of the extra two is minimal. With the internals built like a good modern race TF, there is no reason I can think of that would cause any concerns of explosion. A well built 727 will take that power without issue. Finding an existing clutchflite input shaft that will hold up to that power will be your stumbling block.
Re: clutch flite
[Re: hemicar1971]
#2792869
07/05/20 09:21 AM
07/05/20 09:21 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
With a modern clutch in front of it you could soften the hit and you would be fine. Like already said finding parts would be difficult because much of that stuff is collecting dust WAY in the back of the shop. The few clutch-flites I have seen were 23 spline which is pretty small for an input shaft being sent 1000 HP Good luck Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: clutch flite
[Re: TRENDZ]
#2792875
07/05/20 09:44 AM
07/05/20 09:44 AM
hemicar1971
Chicago Blackhawks
The internals would be all A&A like the TF in the car now so the basic build is as good as it gets. Have acccess to two clutch flites and want to find out the weak points and have stuff made if needed to eliminate these points. If you ever have put all the good stuff in a TF you know it is not a cheap build but to make things last you have to spend money and have access to parts if things go wrong and they will over time, I agree if you are getting one part made that is a one off, build three of them so you are not out for the season waiting for a part. Thank you for the replies, I had heard the input shaft was one of the weak points and posted here to see if anyone had solved that issue. Might have to go back to a Liberty, wanted something that fit like the factory transmission without having to cut more of the car up and using a Clutch Flite things just fit right if it would stand up to the Power and have most of the parts to make one last.
Re: clutch flite
[Re: fourgearsavoy]
#2793043
07/05/20 05:09 PM
07/05/20 05:09 PM
Posts: 289 St.Pete,Florida
lancer493
St.Pete,Florida
Thats an interesting concept of controlling a transbrake the way TRENDZ was describing in the post above. Just like launching a stick car, if I'm understanding it right. Release button activated by clutch pedal. Would require some inhibitor switch integration, preventing against untimely activation.Hemicar1971, would that be legal by the rules you are building to? It seems many convertor driven Torqueflites are staying together in vehicles with weight and horsepower similar to yours.Taking a stout clutch hit of that magnitude with the scattershield adaptor housing, front pump,and trans case being sandwiched together with those skimpy, now longer front pump bolts is asking a lot. Something else that comes to mind is dialing in bellhousing run-out with all those pieces assembled together.I never checked that on mine,being a youngster , but realize that could have been an influence on the seepage that I continually chased.TRENDZ idea of controlling the transbrake with a clutch pedal switch while retaining a torque converter seems worth a look if it were legal for your class.Would definitely need proper electrical/interrupting system to prevent accidental reverse gear engagement as that left leg may want to step on clutch pedal at a BAD time. I am very interested to see where this thread goes as racing with a clutch pedal is ALWAYS a thrill. Bill
Re: clutch flite
[Re: slantzilla]
#2793051
07/05/20 05:26 PM
07/05/20 05:26 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
1200 horse and a Clutch-Flite? That just seems like a bad idea. 2000 hp nitro funny cars used to run them. Lots better internal parts available nowadays.
Re: clutch flite
[Re: John_Kunkel]
#2793062
07/05/20 05:58 PM
07/05/20 05:58 PM
Posts: 1,820 South Bend
John Brown
South Bend
1200 horse and a Clutch-Flite? That just seems like a bad idea. 2000 hp nitro funny cars used to run them. Lots better internal parts available nowadays. Big difference between today's tires that grip, and yesterdays tires that would slip and spin.
Re: clutch flite
[Re: John Brown]
#2793064
07/05/20 06:06 PM
07/05/20 06:06 PM
TRENDZ
Milwaukee WI
1200 horse and a Clutch-Flite? That just seems like a bad idea. 2000 hp nitro funny cars used to run them. Lots better internal parts available nowadays. Big difference between today's tires that grip, and yesterdays tires that would slip and spin. That’s the beauty of the clutch... tune the slip in the bell. Control wheel speed with chassis.
Re: clutch flite
[Re: John_Kunkel]
#2793065
07/05/20 06:10 PM
07/05/20 06:10 PM
hemicar1971
Chicago Blackhawks
Car we are building is an old Pro Stock E Body. It had both a Liberty and a Clutch Flite in it at different times. Ran quicker with the Liberty but things were different back in 1972, but I have no idea of the internals of each transmission when in the car. Looking at running Nostalgia Pro Stock but they have gone to a Clutch pedal format. Every day of the week I would run the A&A TF, that thing in another one of the cars has been the best money spent with little to nothing being hurt. Just rebuild it when needed and everything has been nice when taking it apart. Talked about the pump on another board. Looks like the weak points are the input shaft and the pump. Do not really want to run a Lenco and sold all the the Liberty and Nash stuff a long time ago. I am listening anything else out there that might work, I kind of liked keeping it Chrysler and near to the same as some of the other cars we have. Big Cubes and HP/Torque are one thing that will destroy the Clutch Flite but a slipper clutch might solve one problem. More research needed and a call to A&A might give some answers either good or bad.
Please keep posting anything you know or think, this is a learning curve for us.
Re: clutch flite
[Re: lancer493]
#2793070
07/05/20 06:21 PM
07/05/20 06:21 PM
TRENDZ
Milwaukee WI
TRENDZ idea of controlling the transbrake with a clutch pedal switch while retaining a torque converter seems worth a look if it were legal for your class.Would definitely need proper electrical/interrupting system to prevent accidental reverse gear engagement as that left leg may want to step on clutch pedal at a BAD time. I am very interested to see where this thread goes as racing with a clutch pedal is ALWAYS a thrill. Bill I may have not been clear. I fully intend to use a clutch in combination with a trans brake valve body. No t converter. Transbrake will hold the car in the beams.(no three pedal dance) No plan to use it with the engine power loaded against the trans. By arming a momentary switch on the shifter, with the pedal depressed. In essence, two momentary switches would need to be armed for the transbrake to be on. Release will be a switch on the pedal.
