Minimum rotor thickness
#2792725
07/04/20 06:00 PM
07/04/20 06:00 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
What is the min rotor thickness for my 70 Cuda? Want to know if I have enough meat to have my rotors cut.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: Minimum rotor thickness
[Re: 11secaarcuda]
#2792810
07/05/20 12:19 AM
07/05/20 12:19 AM
Posts: 18,157 Mass
DAYCLONA
Mass
What is the min rotor thickness for my 70 Cuda? Want to know if I have enough meat to have my rotors cut. Depending on the rotors you have, the minimum turn down spec should be cast into the backside of the rotors "hat" area...IIRC for factory rotors it's .980 Mike
