Minimum rotor thickness #2792725
07/04/20 06:00 PM
07/04/20 06:00 PM
WASHINGTON, PA
11secaarcuda Offline OP
WASHINGTON, PA
What is the min rotor thickness for my 70 Cuda? Want to know if I have enough meat to have my rotors cut.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: Minimum rotor thickness [Re: 11secaarcuda] #2792810
07/05/20 12:19 AM
07/05/20 12:19 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Depending on the rotors you have, the minimum turn down spec should be cast into the backside of the rotors "hat" area...IIRC for factory rotors it's .980
Mike
Re: Minimum rotor thickness [Re: DAYCLONA] #2792864
07/05/20 09:08 AM
07/05/20 09:08 AM
VA
dragon slayer Offline
VA
Factory B/E for KH disc was .94"minimum. Original thickness about 1.0" up to 1.010". These were the 10.98" Dia rotors.
Re: Minimum rotor thickness [Re: 11secaarcuda] #2792968
07/05/20 02:00 PM
07/05/20 02:00 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
not our cars but as an example where it appears the minimun thickness
