Stock headlight switch questions #2792401
07/03/20 06:19 PM
07/03/20 06:19 PM
North Central Florida
E
eightlitermopar Offline OP
E
Many of you may have seen my many threads about burning up starters and in dash wiring.
In the process of fixing all those issues, I have a question about the headlight switch.
For 20 years now I have not had "brights" for headlights.
The regular lights work, but when I hit the dimmer switch on the floor, all lights go out. Dash lights, headlights, park lights, everything. So....I simply drove with regular lights. I changed the dimmer switch, and it did not change anything.
However, In my recent search I discovered the in dash switch installed sideways and was actually making contact with my wiper switch. Maybe this was the reason why?
Anyway, finally my question. When comparing the two switches side by side, I see a tab on the new one (circled in red) is this simply a ground?
Thanks!
eightlitermopar
Mopar or no car
Re: Stock headlight switch questions [Re: eightlitermopar] #2792428
07/03/20 08:09 PM
07/03/20 08:09 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Just a ground tab for different applications.
Re: Stock headlight switch questions [Re: eightlitermopar] #2792442
07/03/20 08:53 PM
07/03/20 08:53 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I believe the circuit breaker is integral with the switch, when you hit the brights it trips, when the load lessens it switched back on. Bad breaker is what I've experienced in the past. 2¢
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Stock headlight switch questions [Re: 3hundred] #2792454
07/03/20 09:23 PM
07/03/20 09:23 PM
E
E
I am learning a lot about electrical here. Forgive my ignorance. Where is this breaker? Is it inside the switch itself? Will my changing the switch hopefully fix that issue?
thanks!
Mopar or no car
Re: Stock headlight switch questions [Re: eightlitermopar] #2792457
07/03/20 09:39 PM
07/03/20 09:39 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The breaker is in the switch. Headlights only are on the breaker. The park and dash circuits are on separate fuses that are controlled by the switch.
Re: Stock headlight switch questions [Re: eightlitermopar] #2792484
07/03/20 11:33 PM
07/03/20 11:33 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Sure looks like it's a ground, connection leads to dash frame.
Joe
Re: Stock headlight switch questions [Re: jlatessa] #2792614
07/04/20 12:38 PM
07/04/20 12:38 PM
moparx Offline
moparx  Offline
that would be a ground tab for use mounted in a plastic dash assembly, such as a 74-78 C-body, or possibly an F,R, or J body.
beer
Re: Stock headlight switch questions [Re: moparx] #2793296
07/06/20 09:44 AM
07/06/20 09:44 AM
E
E
beer
Thanks for all the replies. I might add an extra ground wire just to be safe. work
Mopar or no car
Re: Stock headlight switch questions [Re: eightlitermopar] #2793300
07/06/20 09:47 AM
07/06/20 09:47 AM
N
NITROUSN Offline
NITROUSN  Offline
N
beer
All the ground is needed for is the dome light circuit. Nothing else. If your mounting frame is metal don't waste your time.
Re: Stock headlight switch questions [Re: NITROUSN] #2793313
07/06/20 10:24 AM
07/06/20 10:24 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
One way to increase the brightness of your headlights, is to wire in a relay - so when you turn on the "headlights", it turns on the relay - and you wire directly from battery to a circuit breaker, then the circuit breaker to the relay contact on one side, then from the switched side of the contact, to the headlights. This way you get battery voltage DIRECTLY to the headlights. Voltage drop contributes to a drop in light (lumen) output of the headlights . . . and it is less amperage draw on the headlight switch, reducing stress on the wiring.
As to your "new" headlight switch, as was said, the circuit breaker is internal to the switch. The "additional" tab on your switch, is indeed an additional ground . . . good luck !
Re: Stock headlight switch questions [Re: eightlitermopar] #2793404
07/06/20 01:09 PM
07/06/20 01:09 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You should do some research about adding relays to power your headlights. That way the switch is only carrying the low current to the relays mounted on the core support near the headlights, The result is much brighter lights and a longer lasting headlight switch due to less current flowing through the switch twocents
Gus beer
HaHa A12rag was typing the same idea but only faster then me laugh2
64 Plymouth Savoy
Dana 60
Re: Stock headlight switch questions [Re: fourgearsavoy] #2794135
07/08/20 01:08 AM
07/08/20 01:08 AM
E
E
Gus beer
Relays and more LED technology is definitely on my radar. As for now I am trying to track down an electrical short and just get the darn thing running again. Its been sitting for almost two years and I'm starting to go into withdrawals. panic
thanks for all the input!
eightlitermopar
Mopar or no car
