r3 or gen3 #2791487
07/01/20 12:52 PM
07/01/20 12:52 PM
TOMS RIVER
69w2swinger Offline OP
TOMS RIVER
I'm going to replace my w2 340....its been a long time since wrenching it..when it comes to gen3 I'm clueless...my powerwagon runs fine so I never had to work on it.. 5.7 gen3....I'm looking to put together a engine 900-1000hp for my 69 swinger......procharger.....what's needed to achieve close to that HP in a gen3.....I threw this around in other forums here also...
Re: r3 or gen3 [Re: 69w2swinger] #2791535
07/01/20 02:34 PM
07/01/20 02:34 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Forged 392 off of a 6.4 BGE block, boost specific rods and pistons, big valve thitek heads, healthy cam 25x/26x and 15 psi from the blower of your choice. Top if off with the best engine management you can afford.
Nothing crazy for these motors.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: r3 or gen3 [Re: AlexP] #2791609
07/01/20 06:07 PM
07/01/20 06:07 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I agree with Alex, except I'd use the BGE heads for your modest HP goal. I would use a good Aluminum intake, none of the low rise junk.
I'm a NA guy but there are lots of these combos out there
"Just a Bracket car dressed up like a streetcar"
Re: r3 or gen3 [Re: Just-a-dart] #2791854
07/02/20 10:17 AM
07/02/20 10:17 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
You probably can find a G III quicker and for less money than you will find and pay for an R3 or Ritter block.
Re: r3 or gen3 [Re: 340Cuda] #2792309
07/03/20 12:20 PM
07/03/20 12:20 PM
TOMS RIVER
TOMS RIVER
heres what im thinking...2018+ truck 6.4....swap out rods,pistons,cam....use the heads change the springs..new intake and injectors...and procharge it...
Re: r3 or gen3 [Re: 69w2swinger] #2792414
07/03/20 07:14 PM
07/03/20 07:14 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
That would do it.
Re: r3 or gen3 [Re: 69w2swinger] #2792562
07/04/20 09:46 AM
07/04/20 09:46 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Pretty much what I am doing. F3D106 Procharger on a 428 Bge based stroker. Made the engine mount because the gear drive was off a SB Furd. In a 63 Dodge 440.
Re: r3 or gen3 [Re: 69w2swinger] #2792636
07/04/20 01:33 PM
07/04/20 01:33 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Find a hellcat shortblock and put some eagle heads on it .
Invest in a GOOD management system.
Have fun on the cheap.
Hell use a 5.7 eagle engine with a good management system and work out the bugs.
On a sidenote IMO forget about the R3 route. One simple reason is none available.
G3 blow up a block and find another one real easy.
Stock heads kills anything out there.
G3 has issues with rockers and cams but it slowly being sorted out.
For now the stock stuff works in 99 percent of the builds out there.
