Seat back latch #2790618
06/29/20 11:26 AM
06/29/20 11:26 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Hi I’m having trouble getting aligning the seat back to latch in my ‘71 GTX after I had new foam and covers installed. Does anyone have some tricks? Thanks
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Seat back latch [Re: Hrtbkr] #2790769
06/29/20 08:03 PM
06/29/20 08:03 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Bench seat or buckets?
Did you use original catches for the latches or the so-called reproductions that are shorter?
Bump stops installed or left out until the latch catches?
Re: Seat back latch [Re: Hrtbkr] #2790889
06/30/20 06:57 AM
06/30/20 06:57 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Original catches. Are you saying I should remove the bump stop to align the catch? Thanks
Re: Seat back latch [Re: Hrtbkr] #2791101
06/30/20 06:10 PM
06/30/20 06:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You can leave it out or run it all the way in.
Then adjust your latch.
Once it latches to your satisfaction adjust the bump stop so it just makes contact with the washer on the seat base.
Re: Seat back latch [Re: Alaskan_TA] #2791180
06/30/20 07:50 PM
06/30/20 07:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Kinda sounds like too much padding at the bottom of the seat back or top of cushion.
Re: Seat back latch [Re: topside] #2793017
07/05/20 04:05 PM
07/05/20 04:05 PM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Took the bump stop off and it aligned like a champ. It still latches with the stop reinstalled.
Thanks for the tip!
Re: Seat back latch [Re: Hrtbkr] #2793092
07/05/20 07:06 PM
07/05/20 07:06 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Awesome. beer
