Weight Guess? #2790547
06/29/20 12:00 AM
06/29/20 12:00 AM
moparAL Offline OP
moparAL  Offline OP
Help guesstimate weight of car. 70 challenger rolling chassis. No engine, interior, gas tank, everything stripped except wheels, tires, suspension, steering column, steering wheel, just a rolling chassis.
Re: Weight Guess? [Re: moparAL] #2790551
06/29/20 12:20 AM
06/29/20 12:20 AM
Kirkland, Washington
Pacnorthcuda Offline
Just a WAG but I’ll say 1800
You don’t say if front and rear glass is in the car.
Re: Weight Guess? [Re: moparAL] #2790552
06/29/20 12:39 AM
06/29/20 12:39 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Place a scale under tire, one at a time
Re: Weight Guess? [Re: PhillyRag] #2790557
06/29/20 01:05 AM
06/29/20 01:05 AM
moparAL Offline OP
moparAL  Offline OP
Has side glass windows but no front or rear windshields. Also no hood, no hood springs.
Re: Weight Guess? [Re: moparAL] #2790566
06/29/20 05:16 AM
06/29/20 05:16 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This is analog bathroom scale weights of parts of a '69 A-body with front drums in lbs., which should be similar to E-body. All parts are totally bare and without fasteners unless noted.
460 totally naked body shell w paint, w/o undercoating or interior caulking.
32 R or L door, each.
39 trunk.
56 hood.
23 R or L fender, each.
33 K frame, bare.
14 steering gear box w steering arm.
53 all control arms, spindles, steering links, rubber bumpers, bushings, fasteners.
10 center link w idler arm, fasteners.
14 torsion bars, pair, w/o adjusters.
35 pair of front brake drums w wheel studs and outer races, w/o bearings.
49 empty rear axle housing w oil seals, w spring plates, U-bolts, fasteners, w/o brake backing plates.
30 pair of axles w complete bearing assemblies.
67 pig w yoke, w/o bumper support.
92 spring assemblies, pair, w hangers, shackles, bushings, fasteners.
Total of all above is 1,062 lbs w/o wheel/tire assemblies, steering column/steering wheel parts, any hinges, or interior door parts.
Since the weight on each of the 4 wheels is transmitted through a spring or torsion bar, any extremely minor change to any of the spring heights will change the weight under all of the wheels. This means jacking up each wheel and putting a scale under one wheel at a time will yield only false readings. To weigh a car accurately you would need a scale under each wheel simultaneously. Bathroom scales are mostly 300-350 lbs max, so 2 of these would work under front wheels of a stripped down car, but the weight of the rear wheels might be over max capacity of these scales. You could put 2 bathroom scales under each rear wheel with a 2x4 bridge between them. Buy as many as you need and return them after you're finished. whistling
Re: Weight Guess? [Re: kentj340] #2790571
06/29/20 07:07 AM
06/29/20 07:07 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Dang lot of weighing kentj , that's why I love Mopar people they know more about their cars than any other brand lover does. up
Re: Weight Guess? [Re: kentj340] #2790643
06/29/20 12:37 PM
06/29/20 12:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
39 trunk.
56 hood.
33 K frame, bare.
Wow, and I thought I was anal about weighing components... runaway
'63 Dodge 330
11.19 @ 121 mph
