Weight Guess?
#2790547
06/29/20 12:00 AM
06/29/20 12:00 AM
moparAL
Help guesstimate weight of car. 70 challenger rolling chassis. No engine, interior, gas tank, everything stripped except wheels, tires, suspension, steering column, steering wheel, just a rolling chassis.
Re: Weight Guess?
[Re: moparAL]
#2790552
06/29/20 12:39 AM
06/29/20 12:39 AM
Posts: 1,745 Phila
PhillyRag
Phila
Help guesstimate weight of car. 70 challenger rolling chassis. No engine, interior, gas tank, everything stripped except wheels, tires, suspension, steering column, steering wheel, just a rolling chassis. Place a scale under tire, one at a time
Re: Weight Guess?
[Re: PhillyRag]
#2790557
06/29/20 01:05 AM
06/29/20 01:05 AM
moparAL
Has side glass windows but no front or rear windshields. Also no hood, no hood springs.
Re: Weight Guess?
[Re: moparAL]
#2790566
06/29/20 05:16 AM
06/29/20 05:16 AM
Posts: 1,651 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
This is analog bathroom scale weights of parts of a '69 A-body with front drums in lbs., which should be similar to E-body. All parts are totally bare and without fasteners unless noted. 460 totally naked body shell w paint, w/o undercoating or interior caulking. 32 R or L door, each. 39 trunk. 56 hood. 23 R or L fender, each. 33 K frame, bare. 14 steering gear box w steering arm. 53 all control arms, spindles, steering links, rubber bumpers, bushings, fasteners. 10 center link w idler arm, fasteners. 14 torsion bars, pair, w/o adjusters. 35 pair of front brake drums w wheel studs and outer races, w/o bearings. 49 empty rear axle housing w oil seals, w spring plates, U-bolts, fasteners, w/o brake backing plates. 30 pair of axles w complete bearing assemblies. 67 pig w yoke, w/o bumper support. 92 spring assemblies, pair, w hangers, shackles, bushings, fasteners. Total of all above is 1,062 lbs w/o wheel/tire assemblies, steering column/steering wheel parts, any hinges, or interior door parts. Since the weight on each of the 4 wheels is transmitted through a spring or torsion bar, any extremely minor change to any of the spring heights will change the weight under all of the wheels. This means jacking up each wheel and putting a scale under one wheel at a time will yield only false readings. To weigh a car accurately you would need a scale under each wheel simultaneously. Bathroom scales are mostly 300-350 lbs max, so 2 of these would work under front wheels of a stripped down car, but the weight of the rear wheels might be over max capacity of these scales. You could put 2 bathroom scales under each rear wheel with a 2x4 bridge between them. Buy as many as you need and return them after you're finished.
Re: Weight Guess?
[Re: kentj340]
#2790643
06/29/20 12:37 PM
06/29/20 12:37 PM
Posts: 4,651 Wichita
GY3
Wichita
This is analog bathroom scale weights of parts of a '69 A-body with front drums in lbs., which should be similar to E-body. All parts are totally bare and without fasteners unless noted. 460 totally naked body shell w paint, w/o undercoating or interior caulking. 32 R or L door, each. 39 trunk. 56 hood. 23 R or L fender, each. 33 K frame, bare. 14 steering gear box w steering arm. 53 all control arms, spindles, steering links, rubber bumpers, bushings, fasteners. 10 center link w idler arm, fasteners. 14 torsion bars, pair, w/o adjusters. 35 pair of front brake drums w wheel studs and outer races, w/o bearings. 49 empty rear axle housing w oil seals, w spring plates, U-bolts, fasteners, w/o brake backing plates. 30 pair of axles w complete bearing assemblies. 67 pig w yoke, w/o bumper support. 92 spring assemblies, pair, w hangers, shackles, bushings, fasteners. Total of all above is 1,062 lbs w/o wheel/tire assemblies, steering column/steering wheel parts, any hinges, or interior door parts. Since the weight on each of the 4 wheels is transmitted through a spring or torsion bar, any extremely minor change to any of the spring heights will change the weight under all of the wheels. This means jacking up each wheel and putting a scale under one wheel at a time will yield only false readings. To weigh a car accurately you would need a scale under each wheel simultaneously. Bathroom scales are mostly 300-350 lbs max, so 2 of these would work under front wheels of a stripped down car, but the weight of the rear wheels might be over max capacity of these scales. You could put 2 bathroom scales under each rear wheel with a 2x4 bridge between them. Buy as many as you need and return them after you're finished. Wow, and I thought I was anal about weighing components...
