Need help decoding an A833 numbers #2789525
06/26/20 03:41 PM
06/26/20 03:41 PM
SC
V194 Offline OP
V194  Offline OP
SC
Its a long shot guys but I am trying to make sense with some casting and stamped numbers and I need help.
Passenger side:
PP33322(*)5
187915 (a stamping)
Drivers side
C85884
OX5
Any help will be appreciated.
Re: Need help decoding an A833 numbers [Re: V194] #2789578
06/26/20 05:14 PM
06/26/20 05:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Photos of the stamped numbers would help.
Re: Need help decoding an A833 numbers [Re: Alaskan_TA] #2789587
06/26/20 05:27 PM
06/26/20 05:27 PM
SC
V194 Offline OP
V194  Offline OP
SC
Probably would I dont have any handy. Its in the car so its difficult best. I'll see what I can do. Its really hard to see.
Re: Need help decoding an A833 numbers [Re: V194] #2789934
06/27/20 04:12 PM
06/27/20 04:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted by V194
Passenger side:
PP33322(*)5
Should be PP833
22(*)5 is a build date some time in the early '68 model year.
Re: Need help decoding an A833 numbers [Re: John_Kunkel] #2790120
06/27/20 09:50 PM
06/27/20 09:50 PM
SC
V194 Offline OP
V194  Offline OP
SC
Passenger side:
PP33322(*)5
Should be PP833
Thanks John The asterisk is a digit I cannot clearly see.
Would it be legit in a 1970 model year e body? Build date of September 69?
Re: Need help decoding an A833 numbers [Re: V194] #2790193
06/28/20 06:11 AM
06/28/20 06:11 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
A clear photo will help avoid guessing.
Re: Need help decoding an A833 numbers [Re: Alaskan_TA] #2790201
06/28/20 07:30 AM
06/28/20 07:30 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Is there a book or other printed info on how to decode the trans? Then one could do it himself.
Real Men shift for themselves
Re: Need help decoding an A833 numbers [Re: V194] #2790426
06/28/20 05:32 PM
06/28/20 05:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the number is actually in the 22xx range, no. '70 would be in the 28xx-32xx range. As suggested, a pic would help.
Re: Need help decoding an A833 numbers [Re: John_Kunkel] #2790446
06/28/20 07:17 PM
06/28/20 07:17 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& quality responses/decoding require quality info to base the answer on work
which tailshaft is on the transmission? the E-body tailshaft did NOT exist before model year 1970
Re: Need help decoding an A833 numbers [Re: 6bblgt] #2790494
06/28/20 08:30 PM
06/28/20 08:30 PM
SC
V194 Offline OP
V194  Offline OP
SC
I appreciate the help but all of the stamped numbers are really light and mounted in the car so its difficult at best to decipher what I see. I'm doing the best I can.
Its in an Ebody right now. I try to take some shots on Monday.
Re: Need help decoding an A833 numbers [Re: Alaskan_TA] #2790553
06/29/20 12:43 AM
06/29/20 12:43 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Give the man some time, sure it's not a time-sensitive matter to him
Re: Need help decoding an A833 numbers [Re: 1DGEMAN] #2790570
06/29/20 06:39 AM
06/29/20 06:39 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Once again is this TOP SECRET INFO?
Re: Need help decoding an A833 numbers [Re: 1DGEMAN] #2790572
06/29/20 07:12 AM
06/29/20 07:12 AM
VA
dragon slayer Offline
VA
No book, though folks know how to decode the date code, and there is excellent info on casting numbers, bearing sizes, shift lever info etc.... on several websites. No magic identification mark on 4 speed transmissions.
Re: Need help decoding an A833 numbers [Re: 1DGEMAN] #2790574
06/29/20 07:18 AM
06/29/20 07:18 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Brewers performance has some of the casting information, but that does not give specific applications. All parts books have the 10,000 calendar for the specific year. You’ll need all the years to get it complete. There may be a source online for it all in one place. Dave Wise may have some information on decoding the PP833 series of numbers on his site. The vin stamping number, the 0B123456, is best to post it on this site. There are several members who track vin numbers and have access to info the normal guy does not. They can tell you pretty close as to what kind of car it possibly came out of because of when and where the vin numbers falls in sequence. Hope this answers your question.
